19.04.2022, 18:11
I have a request for you.
I have a project where after a year of operation it is necessary to add a KNX relay, but there is no KNX bus. An IP / KNX relay has been installed, but unfortunately I have a problem setting up communication on the LM out to the LAN. I don't have a good LM setup to send data to a LAN. Data from the LAN is written to KNX, but nothing flies from KNX to the LAN.
How do I set up LM to pass KNX addresses to my LAN using multicast?
I have LM set to TP / UART. The IP / KNX device address is 0.2.2, LM has an address of 1.1.1, but it probably won't.
Simply, LM does not drop data into the LAN using multicast.
Can you please advise me, thank you.
