25.04.2022, 13:45
		Hello!
I have IP as backbone and I have 4 logicmachines in 4 floors. I have 2-3 TP lines behind every Logicmachine.
But I have some trouble with filtering and routing between the logicmachines for global group addresses. Can anyone help me and guide me through how to set up the correct parameters for my setup to be able to write from one "main" logicmachine and the other 3 will listen to this logicmachine. Its about 10 global addresses I want all logicmachines to listen to, and theres also about 10 addresses that are unique to each floor, but will be written from the "main" logicmachine.
So far I have access to all logicmachines from the IP network and all LM's have "ack all group telegrams" enabled, "IP > Loc Filter" enabled on all LM's for all addresses except on the "main" LM which have "Loc > IP filter" enabled on all addresses which are global.
Here you can see my settings in KNX connections. Should the filter be enabled here as well? For me it makes no difference to enable it or not.
