25.11.2020, 11:41
		Is it possible in the standard software when using scheduler to say, light on but no earlier than 17:00h? I tried to look at it but could only find offset.
					Scheduler
		25.11.2020, 11:41
		25.11.2020, 11:50
		Can you describe a use case for it? If you want to disallow certain actions depending on time you can simply create an event script.
		25.11.2020, 15:45
		I use this option very commonly with lights that go on and off at homes to show that there is activity when nobody is home. But because nobody would be home before a certain time it would block until a certain time. Example. Lights go on at sunset -30min but not before 17.00 (as nobody would be home before that time) to mimic normal house use as equal as possible.
		25.11.2020, 15:47
		Why don't you just use presence simulation app?
------------------------------ Ctrl+F5
		26.11.2020, 09:44
		30.11.2020, 09:41
	 (26.11.2020, 09:44)KoBra Wrote:I have looked at the function but this only works for me when there are holidays.(25.11.2020, 15:47)Daniel. Wrote: Why don't you just use presence simulation app?Good question, i am not familiar with it? Will take a look at it! Example i want to do is have some light at the door that will go on at sunset but not if sunset is later than 19.00h. I used a lot of MDT central operation units. And there i could select time shift or not before or not after. See below. Is there a way to do this in the logic machine scheduler? ![[Image: download.png]](https://i.ibb.co/DkWyGr1/download.png)
		30.11.2020, 09:48
		There's no such functionality built into schedulers. You will need an extra event script that is executed by a scheduler. It will send true to 1/1/1 if event value is true and current hour is less than 19. Code: value = event.getvalue()
		11.06.2022, 13:32
		Hi. I don't get it. How can I start play recorder objects? (presence simulation app). Playing address? If I set 1 is starting playing and if I set 0 is stoping? or rather by setting scheduler in presence simulation app? Can I play by setting 1 and stoping by setting 0 on KNX/virtual address? Can You explain it for me? Thanks. |
