change value to ## when condition meet
Hello
I read data from generator, but when its off some values gives unreal measurements.
so I want to convert these values to ## when generator is off.
Best Regards,
Similar to this example: https://forum.logicmachine.net/showthread.php?tid=4091
When <body> element has generator-off class then all elements with generator-status additional class will have the current value hidden by setting the text color to transparent and showing a pseudo-element with ## before the value text.
body.generator-off .generator-status.item-value, body.generator-off .generator-status .value {   color: transparent;   } body.generator-off .generator-status.item-value:before, body.generator-off .generator-status .value:before {   color: #333;   content: '##'; }
Thank you admin
So I need the JS from the example before?
But what is the <body> element? Do I need to change it? Is it a variable?
I am not familiar with JS and CSS
Best Regards,
$(function(){   if (window.grp) {     grp.listen('62/7/0', function(object) {       $('body').toggleClass('generator-off', object.value == false);     });   } });
this is the JS Used with the CSS code:
and this is what I got:
Best Regards,
You've probably set custom text color in element properties.
Use this CSS instead:
body.generator-off .generator-status.item-value, body.generator-off .generator-status .value {   color: transparent !important;   } body.generator-off .generator-status.item-value:before, body.generator-off .generator-status .value:before {   color: #000;   content: '##'; }
Thanks Admin
Work Perfect
Best Regards,
