Modbus TCP Slave Problem
I have LM5 with 202112 firmware. I need modbus TCP Slave function and i arranged my residence script like below. I tried with modbus PLC and with some free modbus tool for connection but i received an error like
"COMMUNICATION ERROR
No connection could be made because the target machine actively refused it 192.168.1.81:502 "
My PC IP 192.1681.70 and LM IP is 192.168.1.81 . Is there a problem with 202112 firmware or there is another problem with script ?
Regards
if not mb then
  require('luamodbus')
  -- list of coil mapping, starting from 0
  coils = { '0/1/112', '0/7/112' }
  -- list of register mapping, starting from 0
  registers = { '30/1/1', '30/1/2' }
  -- list of register data types, element count must match registers table
  regdt = { dt.int8, dt.int8 }
  -- knx group write callback
  function knxgroupwrite(event)
    local value
    -- try to find matching coil
    for id, addr in ipairs(coils) do
      if event.dst == addr then
        value = knxdatatype.decode(event.datahex, dt.bool)
        mbConfusedetcoils(id - 1, value)
    -- try to find matching register
    for id, addr in ipairs(registers) do
        value = knxdatatype.decode(event.datahex, regdt[ id ])
        mbConfusedetregisters(id - 1, value)
  -- coil write callback
  function mbwritecoils(coil, value)
    local addr = coils[ coil + 1 ]
    if addr then
      grp.write(addr, value, dt.bool)
  -- register write callback
  function mbwriteregisters(register, value)
    local addr = registers[ register + 1 ]
    if addr then
      grp.write(addr, value, regdt[ register + 1])
  -- knx group monitor, handles group writes
  knxclient = eibdgm:new({ timeout = 0.1 })
  knxclientConfusedethandler('groupwrite', knxgroupwrite)
  -- modbus slave, listen on all interfaces and default port 502
  mb = luamodbus.tcp()
  mb:open('192.168.1.70', 502)
  -- setting slave id is optional
  -- mbConfusedetslave(1)
  mbConfusedetreceivetimeout(0.1)
  mbConfusedetmapping(#coils, 0, #registers, 0)
  -- init coils
    value = grp.getvalue(addr)
  -- init registers
  -- set callbacks for coil and register write
  mbConfusedetwritecoilcb(mbwritecoils)
  mbConfusedetwriteregistercb(mbwriteregisters)
-- handle modbus and knx
mb:handleslave()
knxclient:loop(0.1)
Replace
With
mb:open('0.0.0.0', 502)
(29.06.2022, 09:10)admin Wrote: Replace
With
I changed and i received same result. There is no firewall on the system.
Do a complete script restart via disable/enable. The same script works fine for me with listen IP changed to 0.0.0.0.
