mb:setregisters() and LM values
Hi all,
I think I have figured out the method to read a register and write its value to an LM object
result_5, result_6, result_7, result_8 = mb:readregisters(3203, 4)
if result_5 then
  value5 = bit.lshift(result_5, 48) + bit.lshift(result_6, 32) + bit.lshift(result_7, 16) + result_8
But could you explain to me how to do the opposite with the method "mbConfusedetregisters(register,value)"
from values of LM objects like Uint8, Float32 and Int64?
Thank you in advance for your assistance and have a good week.
See this: https://forum.logicmachine.net/showthrea...833#pid833
So, is this correct to write an INT64 into 4 registers?
value = event.getvalue()
raw = knxdatatype.encode(value, dt.float32).dataraw
r1 = raw:byte(1)
r2 = raw:byte(2)
r3 = raw:byte(3)
r4 = raw:byte(4)
register = 3204
mbConfusedetregisters(register, r4)
mbConfusedetregisters(register+1, r3)
mbConfusedetregisters(register+2, r2)
mbConfusedetregisters(register+3, r1)
You won't have event.getvalue() in a resident script. encode call should have correct data type set as the second argument.
1234567891011121314
value = grp.getvalue('32/1/1') raw = knxdatatype.encode(value, dt.int64).dataraw r1 = raw:byte(1) * 0x100 + raw:byte(2) r2 = raw:byte(3) * 0x100 + raw:byte(4) r3 = raw:byte(5) * 0x100 + raw:byte(6) r4 = raw:byte(7) * 0x100 + raw:byte(8) register = 3204 mb:setregisters(register, r4) mb:setregisters(register+1, r3) mb:setregisters(register+2, r2) mb:setregisters(register+3, r1)
Thank's !
Trying your code with à 12.4 LM object (value = 12345678) I obtain this (writed in log)
string: r4 : 24910 | r3 : 188 | r2 : 0 | r1 : 0
string: Value : 12345678
Readed as 106987647664.13 by the Modbus master !!!
Modbus does not define word/byte order so there are 4 different ways of encoding an int64 value.
Try this:
1234567891011121314
value = grp.getvalue('32/1/1') raw = knxdatatype.encode(value, dt.int64).dataraw r1 = raw:byte(1) * 0x100 + raw:byte(2) r2 = raw:byte(3) * 0x100 + raw:byte(4) r3 = raw:byte(5) * 0x100 + raw:byte(6) r4 = raw:byte(7) * 0x100 + raw:byte(8) register = 3204 mb:setregisters(register, r1) mb:setregisters(register+1, r2) mb:setregisters(register+2, r3) mb:setregisters(register+3, r4)
And this:
1234567891011121314
value = grp.getvalue('32/1/1') raw = knxdatatype.encode(value, dt.int64).dataraw r1 = raw:byte(2) * 0x100 + raw:byte(1) r2 = raw:byte(4) * 0x100 + raw:byte(3) r3 = raw:byte(6) * 0x100 + raw:byte(5) r4 = raw:byte(8) * 0x100 + raw:byte(7) register = 3204 mb:setregisters(register, r4) mb:setregisters(register+1, r3) mb:setregisters(register+2, r2) mb:setregisters(register+3, r1)
Perfect Admin, the second was the good one !
Thank you for your help, the speed of your answers and your professionalism.
