Rotate value (read only)
I have an object that I want to visualize and I want to give it a certain tilt.
This is the css with the custom class .rota
.rota{   transform: rotate(45deg); }
I have added the object, so that it shows only the value and the object rotates perfectly.
The point is that if I click on the object, the wiget appears to change its value and I only want it to be displayed.
So in the visualization I put read only and then it does not rotate.
I have tried to put the important option but cheat.
Interestingly, if I change the color of findo, it works.
Greeting
See this: https://forum.logicmachine.net/showthread.php?tid=4215
It works perfectly.
Thank you very much
