I'm changing the background color of the .item-bgm style with this JS
$(function() {
$('.item-bgm').each(function(_, el) {
var addr = $(el).data('object');
if (addr) {
grp.listen(addr, function(obj) {
var value = obj.value
, background = 'repeating-radial-gradient(red, transparent 150px)'; // default color
if (value > 0 && value < 20 ) {
background = 'repeating-radial-gradient(#0CAFFF, transparent 150px)';
else if (value >= 20 && value <= 23) {
background = 'repeating-radial-gradient(#1DB954, transparent 150px)';
else if (value > 23 && value < 99) {
background = 'repeating-radial-gradient(#7C0A02, transparent 150px)';
$(el).css('background', background);
I want to know if it is possible to change the border color of the css style depending on the mode of the thermostat,
Heating Value - 1byte object
Cooling Value - 1byte object
If heating > 0 then
border: 2px solid red
else if
cooling > 0 then
border: 2px solid blue
else if cooling == 0 and heating == 0 then
border: 2px solid white
$(function() {
if (addr) {
If heating > 0 then
else if
cooling > 0 then
When I click on the temp it will display a widget.
The heating and cooing values are on the widget
Single function can be used if setpoint / heating / cooling addresses have a common scheme where heating / cooling address can be calculated from the setpoint address. Otherwise you will need multiple grp.listen functions where you have to manually specify listening addresses for heating / cooling and the relevant elements to which to apply the styles.
31.10.2022, 12:11 (This post was last modified: 31.10.2022, 12:12 by Fahd.)
(31.10.2022, 12:06)admin Wrote: Single function can be used if setpoint / heating / cooling addresses have a common scheme where heating / cooling address can be calculated from the setpoint address. Otherwise you will need multiple grp.listen functions where you have to manually specify listening addresses for heating / cooling and the relevant elements to which to apply the styles.
Yes, they have the same scheme,
The temp is 17/0/x
Heating value is 18/1/x
Cooling value is 18/3/x
( x is the office number)
