Add objects to Visu by Tag
Is it possible to auto fill a table (or similar) in visu by adding tags to objects?
Can you provide a picture of what you want to achieve?
(28.12.2022, 07:18)admin Wrote: Can you provide a picture of what you want to achieve?
I do not have a screenshot, but to explain more detailed: If I add a tag to a object, I would like for it to automaticly be added to visu. and show value + name. Like a excel spreadsheet of sorts.
You can use .lp server-side script and iframe element to display a table. Upload via FTP using apps login to user directory as objects.lp
Then use /user/objects.lp as iframe source.
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657
<? require('apps') objs = grp.tag('tag_name_here') ?> <!DOCTYPE html> <html> <head> <meta charset="UTF-8"> <title>Objects</title> <link rel="stylesheet" href="/apps/css/bootstrap.css"> <link rel="stylesheet" href="/apps/css/font-awesome.css"> <link rel="stylesheet" href="/apps/css/style.css"> <script src="/apps/js/jquery.js.gz"></script> </head> <body> <table class="table table-hover" style="margin-bottom:0">   <thead>     <tr>       <th>Name</th>       <th>Value</th>       <th>Date</th>     </tr>   </thead>   <tbody></tbody> </table> <script> var data = <?=json.encode(objs)?>; // sort data by name data.sort(function(a, b) {   var na = a.name.toLowerCase()      , nb = b.name.toLowerCase();   if (na > nb) {     return 1;   }   else if (na < nb) {     return -1;   }   else {     return 0;   } }); // show each object name/value/update time $.each(data, function(index, item) {   var trs = $('<tr><td></td><td></td><td></td></tr>').appendTo('tbody')     , tds = trs.find('td')     , d = new Date(item.updatetime * 1000);   $(tds[ 0 ]).text(item.name);   $(tds[ 1 ]).text(item.value);   $(tds[ 2 ]).text(d.toString().split(' GMT')[0]); }); </script> </body> </html>
