17.01.2023, 11:16
(17.01.2023, 07:55)admin Wrote: Try this and post what you get in Logs:
Code:<? require('apps') vars = getvars() log(vars)
SPZ number/LM
17.01.2023, 11:16
17.01.2023, 11:17
Click the log entry. Does it contain any more information?
(17.01.2023, 11:17)admin Wrote: Click the log entry. Does it contain any more information? (17.01.2023, 11:17)admin Wrote: Click the log entry. Does it contain any more information? Maybe text below helps This is from app developer: { "packetCounter":"25523", "datetime":"20181212 163419000", "plateText":"\u0031\u0039\u005a\u0046\u005a\u004c", "plateCountry":"NLD", "plateConfidence":"0.719640", "carState":"new", "geotag":{"lat": 50.418114,"lon": 30.476213}, "imageType": "plate", "plateImageType": "png", "plateImageSize": "0", "carMoveDirection":"in", "timeProcessing":"411", "timeDetection":"20181212 163419000", "plateCoordinates":[480, 270, 216, 30], "carID":"72006", "GEOtarget":"", "datetimezone":"2018-12-12T16:34:19+0200", "carVerticalDirection":"up", "recognitionZone":"1", "imagesURI":["/home/setup/opensdk/html/NumberOkEdgeHanwha/images/images/20181210171447…”, ...], "plateASCII":"19ZFZL", "plateUnicode":"\u0031\u0039\u005a\u0046\u005a\u004c", "sensorProviderID":"CAM_00166CC39D44" }
17.01.2023, 14:00
The documentation does not help as it does not provide the raw request format, only the data that the request contains.
The camera is sending a POST request that LM cannot parse. Unfortunately the raw request is discarded in this case. Run this and post what you get in Logs: Code: <?
require('apps')
log(ngx.var.content_type)
18.01.2023, 04:54
(17.01.2023, 14:00)admin Wrote: The documentation does not help as it does not provide the raw request format, only the data that the request contains.
18.01.2023, 08:04
Next thing to try:
Code: <?
require('apps')
upload()
vars = getvars()
for key, value in pairs(vars) do
log(key, value)
18.01.2023, 12:05
18.01.2023, 12:17
One more thing to try:
Code: <?
require('apps')
sock = ngx.req.socket()
if sock then
sock:settimeout(5 * 1000)
data = sock:receive('*a')
log(data)
log('no request socket')
18.01.2023, 12:54
18.01.2023, 13:06
It should log something even if there's no data (nil). Open the same URL in your browser. Do you get "no request socket" logged?
(18.01.2023, 13:06)admin Wrote: It should log something even if there's no data (nil). Open the same URL in your browser. Do you get "no request socket" logged? browser shows this : Error in /www/user/kam.lp at line 11: attempt to call global ' log' (a nil value) (18.01.2023, 13:06)admin Wrote: It should log something even if there's no data (nil). Open the same URL in your browser. Do you get "no request socket" logged? and nothing in LM log
18.01.2023, 13:53
This is a copy/paste issue. Remove all leading spaces and it will work. The previous example might also work if modified:
Code: <?
require('apps')
upload()
vars = getvars()
log(key, value)
end(18.01.2023, 13:53)admin Wrote: This is a copy/paste issue. Remove all leading spaces and it will work. The previous example might also work if modified:This look to works fine, log rom event below : * arg: 1 * string: event * arg: 2 * string: {"packetCounter":"0", "datetime":"20230119 101832000", "plateText":"\u0050\u0030\u004c\u0049\u0043\u0049\u0045", "plateCountry":"POL", "plateConfidence":"0.843826", "carState":"new", "geotag":{"lat": 49,"lon": 17},"imageType": "plate","plateImageType": "png","plateImageSize": "0","carMoveDirection":"unknown", "timeProcessing":"0", "timeDetection":"20230119 101832000", "plateCoordinates":[737, 137, 63, 20], "carID":"698", "GEOtarget":"/mnt/opensdk/html/NumberOkEdgeHanwha/images/images/2023119101833_58189/2023119101833_58189lp_P0LICIE.png", "datetimezone":"2023-01-19T10:18:32+0100", "carVerticalDirection":"unknown", "recognitionZone":"1", "imagesURI":["/home/setup/opensdk/html/NumberOkEdgeHanwha/images/images/2023119101833_58189/2023119101833_58189lp_P0LICIE.png","/home/setup/opensdk/html/NumberOkEdgeHanwha/images/images/2023119101833_58189/2023119101833_58189lp_P0LICIE.jpeg"], "plateASCII":"P0LICIE", "plateUnicode":"\u0050\u0030\u004c\u0049\u0043\u0049\u0045", "sensorProviderID":"1" } (19.01.2023, 09:23)2MAX Wrote:(18.01.2023, 13:53)admin Wrote: This is a copy/paste issue. Remove all leading spaces and it will work. The previous example might also work if modified:This look to works fine, log rom event below :
19.01.2023, 09:29
This will log the plate number text from the camera event:
Code: <?
require('apps')
upload()
vars = getvars()
data, err = json.pdecode(vars.event)
if type(data) == 'table' then
log(data.plateText)
log('decode failed', err)
end(19.01.2023, 09:29)admin Wrote: This will log the plate number text from the camera event: Thank You very much. It works! But onetimes it send 777706666 on LM, but in log from camera it is 77T706660, any idea why? look pls on red 2023-01-19 16:15:21 (GMT 1),L0GMAX,POL,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 16:02:14 (GMT 1),2BZ8720,CZE,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 15:43:54 (GMT 1),P0ICIE,POL,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 15:42:39 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 15:22:18 (GMT 1),INS1,CYP,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 15:21:36 (GMT 1),IEI723705690,No Country,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 15:04:14 (GMT 1),77T706660,IRL,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 15:04:07 (GMT 1),77770666,ISR,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 15:03:58 (GMT 1),3AL6689,CZE,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 14:15:25 (GMT 1),SANITKAA0,No Country,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 14:12:41 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 14:11:54 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 14:11:26 (GMT 1),3333,LUX,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 14:11:13 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown 2023-01-19 14:10:33 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown
20.01.2023, 07:10
Try using plateASCII instead of plateText. If it still happens then this question should be addressed to the camera manufacturer.
