SPZ number/LM
#21
(17.01.2023, 07:55)admin Wrote: Try this and post what you get in Logs:
<? require('apps') vars = getvars() log(vars)
Click the log entry. Does it contain any more information?
(17.01.2023, 11:17)admin Wrote: Click the log entry. Does it contain any more information?
Maybe text below helps
This is from app developer:
  "packetCounter":"25523",
  "datetime":"20181212 163419000",
  "plateText":"\u0031\u0039\u005a\u0046\u005a\u004c",
  "plateCountry":"NLD",
  "plateConfidence":"0.719640",
  "carState":"new",
  "geotag":{"lat": 50.418114,"lon": 30.476213},
  "imageType": "plate",
  "plateImageType": "png",
  "plateImageSize":  "0",
  "carMoveDirection":"in",
  "timeProcessing":"411",
  "timeDetection":"20181212 163419000",
  "plateCoordinates":[480, 270, 216, 30],
  "carID":"72006",
  "GEOtarget":"",
  "datetimezone":"2018-12-12T16:34:19+0200",
  "carVerticalDirection":"up",
  "recognitionZone":"1",
  "imagesURI":["/home/setup/opensdk/html/NumberOkEdgeHanwha/images/images/20181210171447…”, ...],
  "plateASCII":"19ZFZL",
  "plateUnicode":"\u0031\u0039\u005a\u0046\u005a\u004c",
  "sensorProviderID":"CAM_00166CC39D44"
The documentation does not help as it does not provide the raw request format, only the data that the request contains.
The camera is sending a POST request that LM cannot parse. Unfortunately the raw request is discarded in this case.
Run this and post what you get in Logs:
<? require('apps') log(ngx.var.content_type)
(17.01.2023, 14:00)admin Wrote: The documentation does not help as it does not provide the raw request format, only the data that the request contains.
Next thing to try:
<? require('apps') upload() vars = getvars() for key, value in pairs(vars) do   log(key, value) end
(18.01.2023, 08:04)admin Wrote: Next thing to try:
Log is empty
One more thing to try:
<? require('apps') sock = ngx.req.socket() if sock then   sock:settimeout(5 * 1000)   data = sock:receive('*a')   log(data) else   log('no request socket') end
(18.01.2023, 12:17)admin Wrote: One more thing to try:
still empty, it is 10 minutes after event log on camera
It should log something even if there's no data (nil). Open the same URL in your browser. Do you get "no request socket" logged?
(18.01.2023, 13:06)admin Wrote: It should log something even if there's no data (nil). Open the same URL in your browser. Do you get "no request socket" logged?
browser shows this :
Error in /www/user/kam.lp at line 11: attempt to call global '  log' (a nil value)
and nothing in LM log
This is a copy/paste issue. Remove all leading spaces and it will work. The previous example might also work if modified:
(18.01.2023, 13:53)admin Wrote: This is a copy/paste issue. Remove all leading spaces and it will work. The previous example might also work if modified:
This look to works fine, log rom event below :
* arg: 1
  * string: event
* arg: 2
  * string: {"packetCounter":"0",
"datetime":"20230119 101832000",
"plateText":"\u0050\u0030\u004c\u0049\u0043\u0049\u0045",
"plateCountry":"POL",
"plateConfidence":"0.843826",
"carState":"new",
"geotag":{"lat": 49,"lon": 17},"imageType": "plate","plateImageType": "png","plateImageSize": "0","carMoveDirection":"unknown",
"timeProcessing":"0",
"timeDetection":"20230119 101832000",
"plateCoordinates":[737, 137, 63, 20],
"carID":"698",
"GEOtarget":"/mnt/opensdk/html/NumberOkEdgeHanwha/images/images/2023119101833_58189/2023119101833_58189lp_P0LICIE.png",
"datetimezone":"2023-01-19T10:18:32+0100",
"carVerticalDirection":"unknown",
"imagesURI":["/home/setup/opensdk/html/NumberOkEdgeHanwha/images/images/2023119101833_58189/2023119101833_58189lp_P0LICIE.png","/home/setup/opensdk/html/NumberOkEdgeHanwha/images/images/2023119101833_58189/2023119101833_58189lp_P0LICIE.jpeg"],
"plateASCII":"P0LICIE",
"plateUnicode":"\u0050\u0030\u004c\u0049\u0043\u0049\u0045",
"sensorProviderID":"1"
* arg: 1
  * string: event
* arg: 2
"carState":"new",
"carID":"698",
This will log the plate number text from the camera event:
<? require('apps') upload() vars = getvars() data, err = json.pdecode(vars.event) if type(data) == 'table' then   log(data.plateText) else   log('decode failed', err) end
(19.01.2023, 09:29)admin Wrote: This will log the plate number text from the camera event:
Thank You very much. It works! But onetimes it send 777706666 on LM, but in log from camera it is 77T706660, any idea why?
look pls on red
2023-01-19 16:15:21 (GMT 1),L0GMAX,POL,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 16:02:14 (GMT 1),2BZ8720,CZE,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 15:43:54 (GMT 1),P0ICIE,POL,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 15:42:39 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 15:22:18 (GMT 1),INS1,CYP,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 15:21:36 (GMT 1),IEI723705690,No Country,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 15:04:14 (GMT 1),77T706660,IRL,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 15:04:07 (GMT 1),77770666,ISR,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 15:03:58 (GMT 1),3AL6689,CZE,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 14:15:25 (GMT 1),SANITKAA0,No Country,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 14:12:41 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 14:11:54 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 14:11:26 (GMT 1),3333,LUX,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 14:11:13 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown
2023-01-19 14:10:33 (GMT 1),5M83333,CZE,Not in list,Save to SD Sent to NVR,Unknown
Try using plateASCII instead of plateText. If it still happens then this question should be addressed to the camera manufacturer.
