I use LM5CAN also have DALI switch (SR-2422k8).
When a button is pressed, I see it in the monitor (attach.) it can be processed using a script, if I understand correctly.
Could you provide an example of how to handle this click, for example, to the address 5/3/3
I saw this https://openrb.com/docs/dali.htm and https://forum.logicmachine.net/showthread.php?tid=2387 ,but not understand how to right implement this.
Thank you in advance !
