(02.02.2023, 11:04)Daniel Wrote: I'm using innr plugs and they do extent the network only with a limited range. It takes a bit of time for the new network to get established. Zigbee mesh is self learning and it needs a bit of time to adjust. Look on the network map to see how all is connected.
I've tested it on two of our customers, LM5 with USB gateway, 2x INNR s.p. and they have used the system for like 4 months. I've tested it several times, in different days, reloading the network map during the week to see if something change. The two devices were never online trough the smart plug, always trough gateway with signal going between 0% and 5% , and the plug was like between 30 and 40%. The probe was near the plug. I've tested it with Sonoff SNZB, Moes T°/H%/lux and Tuya T°/H%. I've also tried to change the plugs with others but nothing changed.
Don't know if within the newest updates something has changed.
I'll try recreating the same system with RS232 gateway and track a network map to share the results.
Updates:
After 5 days of testing, my INNR plugs wont extend anything. As you can check by the map, no devices are connected to the sp but Wiser VA6 and Tuya 2 are near Smart Plug 2 and Wiser VA 5 and Tuya are near Smart Plug 1. I've tryed several times to pair again the devices with the gateway but i never see this devices linked toghether.
The device on the picture seems not to be connected but i'm able to send/receive data from everyone of them and i can send commands too and they do their things. Looks a bit strange. As you can see on the device list no one seems to be disconnected, at least on the signal intensity and the last message.
If plugs are not sending anything for some time they are marked as "offline" and are not queried when building the map. Go to "Control & status", read both plug status, then refresh the network map. It should show all routes then.
(08.02.2023, 08:46)admin Wrote: If plugs are not sending anything for some time they are marked as "offline" and are not queried when building the map. Go to "Control & status", read both plug status, then refresh the network map. It should show all routes then.
Hi admin, already done, several times. Before reloading i've tryed to move on and off the plugs too but nothing. I've tested it out with another 2 INNR plugs that we have in stock, but no changes.
Even with this tricky signals, the systems seems to work fine right now. RS232 gateway seems to be so much more reliable than the USB one.
We are facing some trouble with Wiser TRV:
- Noise during night, seems to restart the initialize sequence and join the system again.
- Sometimes they loose the occupied setpoint and reset it to 20°C randomly. Even if we haven't used the plus/minus rotation to change it.
So we have searched for something different, but that's not the correct item
I think you have to sent to them setpoint periodically, otherwise they assume lost connection and goes to default self operation.
23.02.2023, 19:55 (This post was last modified: 23.02.2023, 20:00 by MLa.)
@admin
This is the features for the elko thermostat.
ESH Super TR RF PH - Thermostat
Read floor and air temp
Read/Write Thermostat set temp (if thermostat mode)
Read/Write Regulator % (if regulator mode)
Read Heating status
Read Child lock status
Read Temperature Mode (Floor, Air, Floor Guard)
Advanced settings:
Set heating cable effect (watt) to get correct kw/h readiuts
Set max floor temp when used as floor guard
Time between on/off on relay
Temperature calibration
I'm having some problems with my zigbee devices.
I can control them from zigbee app and group adresses, but they do not update the status group adresses.
When I use the read buttom in zigbee app, I get the correct status.
What can be the reason?
