JS'ed SVG for Siemens RDG1x0KN thermostats
Hi All,
I spent today trying to reproduce Siemens thermosta in SVG, scripted in JS for getting values.
Please use it as image and not icon and edit with a text editor to adjust group addresses.
Enjoy
Luca
UPDATE: I'm using it with a two pipes plant in two-stage configuration. Object from thermostat are:
1) primary heating -> 25 Heating output primary
2) secondary heating -> 26 Heating output secondary
3) primary cooling -> 27 Cooling output primary
4) speed -> 35 Fan output
5) mode -> 16 Room operating mode: State
6) temperature -> 21 Room temperature
7) setpoint ->  24 Room temp: Current setpoint
.svg   Siemens-RDG1x0KN-Thermostat.svg (Size: 11.79 KB / Downloads: 60)
Please check this example of svg controlled via js:
http://forum.logicmachine.net/showthread...275&page=4
I can also prepare something to start for you. If this wouldn't work please change '0' to '1' or other value, it depends on how many other images do you have in your visualisation.
$(function(){   $('object').load(function() {          var svg = $('.siemens')[0].firstChild; // Choosing svg              var svgDoc = svg.contentDocument; // Choosing content from svg     var temperature = svgDoc.getElementById("temperature"); // Choosing temperature from content     var setpoint = svgDoc.getElementById("setpoint"); // Choosing setpoint from content     var primary = svgDoc.getElementById("primary"); // Choosing primary from content     var secondary = svgDoc.getElementById("secondary"); // Choosing secondary from content     var radiator = svgDoc.getElementById("radiator"); // Choosing radiator from content     var speed0_16 = svgDoc.getElementById("speed0_16"); // Choosing speed0_16 from content     var speed16_33 = svgDoc.getElementById("speed16_33"); // Choosing speed16_33 from content     var speed33_50 = svgDoc.getElementById("speed33_50"); // Choosing speed33_50 from content     var speed50_83 = svgDoc.getElementById("speed50_83"); // Choosing speed50_83 from content     var speed83_100 = svgDoc.getElementById("speed83_100"); // Choosing speed83_100 from content     var fan = svgDoc.getElementById("g24"); // Choosing fan from content     var heat = svgDoc.getElementById("g39"); // Choosing heat from content     var cool = svgDoc.getElementById("g34"); // Choosing cool from content     // Update temperature     actual_temp = Scada.encodeGroupAddress('1/1/10'); // temperature     objectStore.addListener(actual_temp, function(obj, type) {     console.log(temperature, obj.value)     temperature.textContent= obj.value     });      });   });
At this moment I have only time for such little helpSad Maybe tomorrowWink
I see also some buttons, can you describe how do you change parameters on real thermostat?
(12.01.2017, 21:54)buuuudzik Wrote: Please check this example of svg controlled via js:
$(function(){   $('object').load(function() {          var svg = $('object')[0]; // Choosing svg              var svgDoc = svg.contentDocument; // Choosing content from svg     var temperature = svgDoc.getElementById("temperature"); // Choosing temperature from content     var setpoint = svgDoc.getElementById("setpoint"); // Choosing setpoint from content     var primary = svgDoc.getElementById("primary"); // Choosing primary from content     var secondary = svgDoc.getElementById("secondary"); // Choosing secondary from content     var radiator = svgDoc.getElementById("radiator"); // Choosing radiator from content     var speed0_16 = svgDoc.getElementById("speed0_16"); // Choosing speed0_16 from content     var speed16_33 = svgDoc.getElementById("speed16_33"); // Choosing speed16_33 from content     var speed33_50 = svgDoc.getElementById("speed33_50"); // Choosing speed33_50 from content     var speed50_83 = svgDoc.getElementById("speed50_83"); // Choosing speed50_83 from content     var speed83_100 = svgDoc.getElementById("speed83_100"); // Choosing speed83_100 from content     var fan = svgDoc.getElementById("g24"); // Choosing fan from content     var heat = svgDoc.getElementById("g39"); // Choosing heat from content     var cool = svgDoc.getElementById("g34"); // Choosing cool from content     // Update temperature     actual_temp = Scada.encodeGroupAddress('1/1/10'); // temperature     objectStore.addListener(actual_temp, function(obj, type) {     console.log(temperature, obj.value)     temperature.textContent= obj.value     });      });   });
HI  @buuuudzik,thanks for your hints. I've used embedded js at the moment. I'm not so familiar with js. I've used edgars example and tried to adapt it to my use case. I'll have a look at you example for custom js. It would be better because we can use only one instance of the image. I don't really know how to identify them from custom js.
I actually change parameters with standard visualization objs. The thermostat is read only at the moment.  Shy
Buttons and rotatory are not yet used (really i don't know how to get events from SVG and make them change objs status). Could you give some other hint for both questions?
PS: I've updated the image in first post.
I've updated above script and now when you use it and add Custom class "siemens" to your svg image i visualisation editor, script should work.
This is for writing value from Group address(1/1/10) to svg element(temperature), but user can't change this value:
// Update temperature actual_temp = '1/1/10'; // temperature grp.listen(actual_temp, function(obj, type) { temperature.textContent= obj.value });
The problem(for me) is how to prepare the edit function. At this moment I can prepare this by adding some special buttons + and minus or clicking on symbols.
Maybe Edgars can tell how it is possible in other way(e.g. like it is with changing temperature on default visualisation)Wink
