Hello
I just updated mosaic 2.0 and noticed some issues
error log is full with mosaic 2.0 errors,
Nicky
- every minute the following is logged
- Line 6: module 'mqtt_library' not found: no field package.preload['mqtt_library'] no file './mqtt_library.lua' no file '/usr/lib/lua/mqtt_library.lua' no file '/usr/share/lua/mqtt_library.lua' no file '/usr/lib/lua/mqtt_library.so'
- Setting the position status object results in not being able to move blinds up and down since the + and - have been inverted since mosaic 1.0
- - moves down since mosaic 2.0 (mosaic 1 it moved up)
- + moves up since mosaic 2.0 (mosaic 1 it moved down)
- when position status object is set and screen is down or up you cannot move it anymore
Nicky
