Multiple PID
Goodmorning everyone.
I have a problem I can not make more PID function simultaneously.
Can someone help me. Thank you
Like this:
12345678910111213141516
if not p1 then   p1 = PID:init({     current = '1/1/1',     setpoint = '1/1/2',     output = '1/1/3'   })   p2 = PID:init({     current = '2/1/1',     setpoint = '2/1/2',     output = '2/1/3'   }) end p1:run() p2:run()
Try this (see attachments)
.lua   PID modified version 1.1 Resident Script.lua (Size: 13.05 KB / Downloads: 47)
.lua   PID modified version 1.1 User Lib.lua (Size: 5.99 KB / Downloads: 33)
good morning, thanks for the kind risposta.ma I can not upload the files you sent me. Can you help me.
The files are not export/import format but manualy created.
Just open them with a text editor (notepad++ or wordpad or something) and create a user lib called 'pid' and a resident script and past the content manualy to them.
thank you so much
still one last question. To slow down a bit the speed of PID how they work the following values? :
     kp = grp.getvalue ('3/3/105'),
     ki = grp.getvalue ('3/3/106'),
     kd = grp.getvalue ('3/3/107'),
Thanks again for your valuable contribution.
This is project / system configuration related, i would start with 0.3 for all and from there fine tune between 0 to 1 if you need to reduce overshoot or need more agresive loops.
