visualization https
I have a problem with the display in the visualization. I have inserted an Https link into a page from my network device at my house. Then shows our connection and cannot open the page. But if I open this link as a second tab in the browser, it is opened and displayed. How can I fix the problem?
If it opens in another tab then it is something with your browser not LM. Clear browser cache.
The first time I opened it, I was able to allow it insecurely in the browser, since then I can always open it. But I can't do that in the visu.
Press F12 and check if you have any errors in the console.
Use SSL certificate app to generate proper certificate so the browser will not complain.
thanks I'll test it. The visu can be opened and operated, only the page with the frame with the https address is not opened
Most probably the page is sending a special header to the browser that forbids inclusion via iframe.
how can I avoid that?
It is a browser security feature that cannot be disabled.
In LM there's a special setting that allows to include one LM in another via iframe.
okay I have to look for where I can set it
