Decimal number on Mosaic
Dear all,
I am reading some values in modbus with 2 decimal number (ex. 0,28 Kw). In Mosaic I read 0,3 kW and I do not know where I can increment decimal number on Mosaic.
Can you help me please?
Which widget are you using?
(12.07.2023, 07:43)Daniel Wrote: Which widget are you using?
In the widget editor I use the same status label for the temperature.
Info 2 widget will give you two decimals, see if this could work for you.
