01.07.2023, 08:30
Hi we have to create trnds chart with voltage L1 and Voltage L2 can you tell me step by step procedure how to create trends and how to add in the UI and how to import scrip where it import
Trend Visulaisation
01.07.2023, 08:30
03.07.2023, 09:22
Check LM manual starting from page 48: https://openrb.com/wp-content/uploads/20...3.2022.pdf
For voltage you need to use absolute value trend log type.
what data type have to select (in the object)for my register is 32bit unsigned register
Thanks for the replay
Can I get best Graph UI for Industrial measure voltage electricity and power will mostly compare voltages,if we want add script where to add?suggest me with steps,Thanks
04.07.2023, 10:04
Just go to home and click on Trends logs, in there you can compare multiple trends.
04.07.2023, 10:22
Thanks,
I got that,but i want best UI with scripting
04.07.2023, 10:30
It is not very clear what you are looking for so cannot suggest any solution.
08.07.2023, 10:47
Is it possible to see the trends in the Logic Machine app on the smartphone? Thank you.
28.07.2023, 10:01
28.07.2023, 10:15
Yes, click X in top right corner to close Mosaic and then open Trend log
28.07.2023, 15:21
28.07.2023, 15:34
Make sure you have latest LM Cloud app and it is configured then sync and check again. You need some trends on LM too.
28.07.2023, 15:50
(28.07.2023, 15:34)Daniel Wrote: Make sure you have latest LM Cloud app and it is configured then sync and check again. You need some trends on LM too. The LM app on my android is Version 1.0.11 I just updated LM cloud to the latest version and re-synced, but I get the same error. I have tried in another LM and I get the same error
28.07.2023, 16:02
This error says that you have no trends to see. Do you have any trends in LM?
Which firmware do you use? What does the log says in LM cloud app?
28.07.2023, 16:05
(28.07.2023, 16:02)Daniel Wrote: This error says that you have no trends to see. Do you have any trends in LM? I have 33 Trends created. The LM CLoud Log says: 2023.07.28 17:53:01 config sync finished for trends (1195) 2023.07.28 17:53:00 config sync finished for users (2) 2023.07.28 17:53:00 config sync finished for objectunits (1234) 2023.07.28 17:52:59 config sync finished for objectnames (36277) 2023.07.28 17:52:59 config sync finished for objects (7556) 2023.07.28 17:52:58 config sync finished for mosaic (284200) 2023.07.28 17:52:58 config sync finished for base (37) 2023.07.28 17:49:14 config sync finished for trends (1195) 2023.07.28 17:49:13 config sync finished for users (2) 2023.07.28 17:49:13 config sync finished for objectunits (1234) 2023.07.28 17:49:13 config sync finished for objectnames (36277) 2023.07.28 17:49:12 config sync finished for objects (7556) 2023.07.28 17:49:12 config sync finished for base (37) 2023.07.28 17:49:11 connection OK 2023.07.28 17:49:11 connection started 2023.07.28 17:47:40 config sync finished for trends (1195) 2023.07.28 17:47:40 config sync finished for users (2) 2023.07.28 17:47:39 config sync finished for objectunits (1234) 2023.07.28 17:47:39 config sync finished for objectnames (36277) 2023.07.28 17:47:38 config sync finished for objects (7556) El LM tiene la firmware: HW: LM5 Lite (i.MX6) SW: 20210806
28.07.2023, 16:11
Install 2023 firmware.
