iFrame Problem / https mixed content
I would like to integrate a ventilation system via iFrame in my Layout.
The problem is the page does not load.
If i try with local test.html it works as it should.
So i think there is no iFrame block from the Source.?.
So actually i`m not sure whats the Problem.
1.Http Source Ventilation System
2.SchneiderMachine/LogicMachine
3.Browser Secruity
Hopefully you can help me to find a good solution.
Greetings.
Make sure to have Allow external access via iframe enabled in vis config
Problem solved!
I allowed external access via iFrame.
And had to be sure that the access to Visualization is made over Http.
So there is no mixed Content that blocked by Browser.
