Group Address export for ETS
I would like to export all group address from the logicmachine and import them into ETS.  Can this be done?
Reason being you can add lots of modbus data points and automatically link group addresses to them quickly in the logicmachine.
This old script by Erwin might work: https://forum.logicmachine.net/showthrea...13#pid6713
(17.10.2023, 13:38)admin Wrote: This old script by Erwin might work: https://forum.logicmachine.net/showthrea...13#pid6713
Thanks,
I actually used the script by Daniel,  Used ftp to download the file which worked well.  Only issue it doesn't have data type assigned,  Could this be added?
This script generates CSV with datatypes that can be imported into ETS 6.1.0. csv variable contains the CSV file data as a string.
function csvescape(val)
  val = tostring(val)
  val = val:gsub('"', '""'):gsub('^[-=+@\t\r]', "'%0")
  return '"' .. val .. '"'
function getdpst(dpt)
  dpt = tonumber(dpt)
  if not dpt then
    return ''
  elseif dpt < 1000 then
    return 'DPT-' .. dpt
    local mdpt = dpt % 1000
    dpt = math.floor(dpt / 1000)
    return 'DPST-' .. dpt .. '-' .. mdpt
objs = grp.all()
buf = { '"Group name";"Address";"Central";"Unfiltered";"Description";"DatapointType"' }
for _, obj in ipairs(objs) do
  if obj.id < 0x10000 and obj.datatype and obj.datatype ~= 255 then
    row = {
      csvescape(obj.name or ''),
      csvescape(obj.address),
      csvescape(obj.comment or ''),
      csvescape(getdpst(obj.datatype)),
    buf[ #buf + 1 ] = table.concat(row, ';')
csv = table.concat(buf, '\n')
