05.01.2024, 10:46 (This post was last modified: 09.01.2024, 06:17 by alexll.)
Hi there,
I'm messing with a Schneider Zigbee Window/door sensor CCT591011, a LogicMachine LM5 Lite and your Zigbee gateway.
The problem is that it easily connects with the Zigbee app, but it only transmits its battery status but not the open/close one.
Every device has a reset procedure, for SE devices it is like that. Press 4 times reset button but after forth press keep holding it for 10 sec. LED should blink red after 10 sec.
Make sure not to press for 20 sec as this is another thing, device will become BLE.
Hi there. Is there any way to make a Zigbee read command by script? IKEA TRÅDFRI bulbs stop sending its status after a power cycling, but they update it if you press the "Read" button inside Zigbee app. Thank you!
09.01.2024, 10:25 (This post was last modified: 09.01.2024, 16:39 by alexll.)
(09.01.2024, 08:24)admin Wrote: This a known bug in Ikea lamps, we will see if some workaround can be implemented to restore the status reporting. For reading statuses check this example: https://kb.logicmachine.net/libraries/zi...-responses
I am aware of this. Thank you for the example!
EDIT: I have tried this code as resident script and it works flawlessly:
I have same problem with SE CCT591012. I test 2 device with same result. Tried to reset and pair again, always same, battery state can be see, however the contact sensor don't come.
I don't try to change channel... I I do this, should I reappair all other device too ?
SE ECO EXPERT
It won't work without a profile. Provide a complete report from the info window (in text form, not as a screenshot). Don't change the channel, it won't help.
(18.01.2024, 14:08)admin Wrote: It won't work without a profile. Provide a complete report from the info window (in text form, not as a screenshot). Don't change the channel, it won't help.
It is the same device as mine. I had to full reset the Schneider door contact several times until achieving a proper operation. Once you achieve it, I will work flawlessly forever.
ok thanks, I have the LSS100400
I reset it at least 4 times without change. I test 2 of it. I will report to SE
SE ECO EXPERT
Still no feedback from Schneider... They gave me 10 of it and can't use it, only batterie info...
I try reseting the product several times (3press then a long, and pair again with 3 press), but still same issue, also with different product.
any help appreciate
SE ECO EXPERT
Enable debug logs in ZigBee app configuration, try pairing again and send the logs to us. When pairing try moving the device as close as possible to the coordinator.
31.01.2024, 08:56 (This post was last modified: 31.01.2024, 09:48 by domotiqa.)
strange... I post again
don'"t work...
here a link https://gofile.io/d/GNyJe2
I update firmware with a new one receive for field test (preprod) and with this one I success using it...
don't know why
SE ECO EXPERT
31.01.2024, 10:36 (This post was last modified: 31.01.2024, 10:47 by domotiqa.)
No finaly I had a second and have no detection.
I continue my test. I reset again an once detected, I quick create the 3 object (detection, batterie...) with virtual address quick creation.
Then it s ok.
I can after that assign to my well address. Don't know if it s accident, but I have my contact this way
SE ECO EXPERT
