BACnet connection fail
I need help, I have an LM5 on a network with the following parameters:
IP address: 143.3.123.8
Subnet mask: 255.255.255.224
Default gateway: 143.3.123.1
When I try to connect with BACnet software such as BDT (BACnet Discovery Tools), the LM5 is not discovered.
If I try the same connection with another IP address (private segment and 24-bit subnet mask), BACnet is discovered without any problem.
I think the problem is the public IP address, but I don't know if the problem is with the BACnet protocol or the LM5 firmware.
Regards.
Same problem...
IP address: 105.50.204.150
Subnet mask: 255.255.255.128
Default gateway: 105.50.204.129
with yabe is not discovered but i i change thr Subnet mask to 255.255.255.0 is ok.
Any help?
This is public IP and it is blocked for security.
Hi Daniel, there is a way to force it ?
I received this configuration from the IT manager of the company... now i can't export the knx point to the BMS.
