CPU charge...
one of my HW 2 Schneider Electric indicate as "CPU/IO : 4.81 5.2 4.1 - Memory 20%" and it is quite slow.
Are these values normal or it is a problem ?
- 480 objects
- 1 cylclic script (15s)
- few plans
- some JS
- ..etc...
Good end of day.
Thank's in advance for your answer.
The values are very much not normal, CPU I/O should be below 1. Install Process app to see what is consuming so much.
I don't know this !
How to intall this App ?
On homepage in top right corner there is a shopping basket, click on it and you will go to app store where you will find Processes app. Install it open and drop screenshot of what you see.
I found that it is this cyclic script (15s) which increases the CPU load from <1 to 5...6... !!!
obj_surv_generale = "20/1/20" lst_grp = { {"20/1/1",""}, {"20/1/2",""}, {"20/1/3",""}, {"20/1/4",""}, {"20/1/5",""}, {"20/1/6",""}, {"20/1/7",""}, {"20/1/8",""}, {"20/1/9",""}, {"20/1/10",""}, {"20/1/11",""} } nbr_alarme = 0 for i,grp_tbl in ipairs(lst_grp) do   obj_alarme = grp_tbl[1]   -- log(i, obj_alarme)   val_alarme = grp.getvalue(obj_alarme)   if val_alarme == true then     nbr_alarme = nbr_alarme +1   end end if nbr_alarme == 0 then   grp.write(obj_surv_generale,false) else   grp.write(obj_surv_generale,true) end
Use OR gate from this example.
https://kb.logicmachine.net/scripting/lo...-statuses/
