Max number of http/https client for LM5
I would like to know if there is a limit for the number of concurrent clients in http/https, e.g. using one LM5 with 6/7 tablets at once could be a problem?
Thank you
It will work fine, LM can handle much more connections. There's no exact limit as system resources are shared between different processes (scripts, apps, etc).
(10.04.2024, 07:13)admin Wrote: It will work fine, LM can handle much more connections. There's no exact limit as system resources are shared between different processes (scripts, apps, etc).
Thanks!
