How to execute json link inside spacelynk
Hi guys,
I have SpaceLynk and I enabled remote service in order to use json, I can execute this "(https://192.168.0.90/scada-remote?m=json...&value=off)" through my network.
But I want to execute this between two spacelynks gateway.
Is there any lua script can help me to achieve that?
because i want to read and write values between two spacelynk gateways in the same network.
Thanks for all
Mohammad
Why don't use use KNX/IP Routing for local data exchange? It does not require any scripts.
The correct usage via script is this. Change RemotePassword to the actual password.
http = require('socket.http')
res, err = http.request('https://remote:RemotePassword@192.168.0.90/scada-remote?m=json&r=grp&fn=write&alias=0/0/1&value=true')
log(res, err)
For 1 bit objects valid values are true/false or 1/0.
