20.06.2024, 15:37
		Hello colleagues, I hope you are excellent. The following thread is to tell you that I am having problems getting the ETS to connect to several logic machines to be able to program through it. The problem is when I set the next range to the logic machines 20.20.109.XXX, with mask 255.255.255.0 and gateway 20.20.109.1, the ETS does not find the interfaces even by adding them manually (since it throws an error when trying connect), on the other hand, if I configure the logic machines in the network range 192.168.0.XXX, with mask 255.255.255.0 and gateway 192.168.0.1, the ETS does find them automatically and can connect to them . I did the test with another KNX/IP device (Zennio IP Interfaces Pless) I put the IP address 20.20.109.105, with mask 255.255.255.0 and gateway 20.20.109.1 and the ETS found it automatically and can connect to it . It should be noted that the tests I did were using a simple unmanageable switch and connecting directly between my PC and the logic Machines, obtaining the same results.
