Communication between virtual objects from different lms
Hello everyone,
Assuming that we have more than one lm in a project, is it possible to communicate between their virtual objects ?
If yes, how is this possible?
Thank you in advance.
Not via KNX IP but you can use Webservices, bacnet, modbus IP, MQTT.
(21.06.2024, 08:51)Daniel Wrote: Not via KNX IP but you can use Webservices, bacnet, modbus IP, MQTT.
Could you give us an example with bacnet or modbus IP, please?
With bacnet, one device must be a server and second a client.
https://kb.logicmachine.net/libraries/bacnet-client/
https://kb.logicmachine.net/integration/bacnet-server/
For modbus one device must be modbus tcp slave
https://kb.logicmachine.net/integration/...tcp-slave/
and on second create a profile for it under Modbbus tab
https://kb.logicmachine.net/misc/modbus-profile/
