07.07.2024, 09:09 (This post was last modified: 07.07.2024, 09:34 by arturfra.)
i can't control my umidity sensors because home kit wants "scale" datatypes instead my sensors want "byte floating", how could i resolve the issue?? TNX in advance
You need to create an event script for conversion using a virtual object.
tnx for reply, could you post an example ??
Try something like this:
Consider 1/1/1 the umidity value and 32/0/0 the virtual object for home kit
Event script on 1/1/1
Value = event.getvalue()
grp.update('32/0/0',(math.modf(Value)),dt.scale)
07.07.2024, 13:08 (This post was last modified: 07.07.2024, 13:31 by arturfra.)
(07.07.2024, 11:57)CristianAgata Wrote:
(07.07.2024, 11:05)arturfra Wrote:
(07.07.2024, 10:45)CristianAgata Wrote:
(07.07.2024, 09:09)arturfra Wrote: Hi,
tnx indeed ! It works...
for reading the values OK but now i've to write the desidered humidity value and i've to convert from scale to floating byte, the opposite.. how i should go forward ? Tnx
i solved:
grp.update('2/0/9',(math.modf(Value)),dt.float16)
After pairing Homekit-app with Apple Homekit, Apple Homekit writes that this bridge is not certified to use with Apple Homekit. Not that it matter - it works perfectly well. Just curious if this is a bug in my setup or it's the way it supposed to be.
do you plan to add door but with toggle function. most of our installation are made with only knx delayed output (pulse) for control, and a contactor on input device. It is the most common use for controlling easily a door. this function is on other controller like jeedom, has, confortclick... should be great to have it also (only to variable control toggle and feedback)
SE ECO EXPERT
