Put objects of a template on top of the page
is it possible to put objects from a template on top of every other objects in the page that use the template? I tried wit z-index but it doesn't work.
It's only possible to put the whole layout on top of the plan via CSS:
.layout {   z-index: 7; }
Ok, so if I have widgets on the pages and not on the layout basically I can't use it, right?
Thanks for your help
Can you provide an image of what you want to achieve?
Basically I would like to have a simple page like that (it's just a scheme)
That when I press a button on the side menu cover the portion with the widget with another color and deactivate the widgets like that
Everything works fine except for the cover part
If you link a menu item with a widget then the widget contents will be placed on top everything else because widgets are placed on a separate layer that has higher z-index than plan and layout.
Yes, but the menu is on a layout and the widgets are on a page
