Zigbee gateway integration
There should not be any difference between heating and auto mode so that's why the control is binary.
We've only implemented most common features because we don't have the actual device to test the integration. Which other features are you missing?
(03.10.2024, 13:31)admin Wrote: There should not be any difference between heating and auto mode so that's why the control is binary.
That is not correct unfortunately. The auto mode is controlled by week timers and what not, the only functional mode on this heater is "Manual", where the heater is working after the given setpoint, so this is absolutely necessary for basic operation.
What we would like for our implementation is KeypadLockout and DisplayAutoOffActivation.
EDIT: As it is now, we have no way of setting the panel heater back to manual when the user changes to auto, neither any way to block local user input.
(03.01.2022, 06:41)admin Wrote: You will need additional hardware for this. See this guide: https://www.zigbee2mqtt.io/guide/adapter...c2531.html
Checked! It worked on the first try. But be careful, in my case it worked with a bare CC2531 board without any prior configuration.
Hello Community. Has anyone tried this sensor with LM? I would like to know in order to implement it in a project. I have a bare board CC2531 from TI with firmware (Z-Stack_Home_1.2 20211115/20211116) CC2531_DEFAULT_20211115 from github
https://www.zigbee2mqtt.io/devices/Open'...lec-open-r
can i have the zigbee ipk for offline ?
Thanks. I tried :
https://dl.openrb.com/pkg/zigbee-20240522.ipk
but doesn't work
SE ECO EXPERT
I have this zigbee lamp INNNR RB255C
I can ON/OFF, LEVEL, but not RGB control.
Can you add the profil ?
Thankx
12345678910111213141516171819202122232425262728293031323334
Manufacturer: innr Model: RB 255 C Firmware version: 2.04.08 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - LightingColorCtrl (768) - LightLink (4096) - 64599 - 64642 Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 254 - level: 254 - onoff: true - prevlevel: 254
SE ECO EXPERT
(07.10.2024, 11:55)domotiqa Wrote: can i have the zigbee ipk for offline ?
Thanks. I tried :
but doesn't work
SE hardware has special modifications and our zigbee apps are also different. Due to hw none compatibility we do not share our app as SE users like you might want to use it and have issues.
Contact SE support for both topics.
Thanks. I tried :
but doesn't work
ok thanks but I also have Lmachine on our company, not only SL HL
SE ECO EXPERT
I've tested several zigbee thermostats and none of them work properly.
The last one I tested complies with the Zigbee 3.0 standard but doesn't work either.
Can you integrate one?
I'm looking for a thermostat with an outdoor temperature sensor.
the last file
Vir (33)Vimar - WheelThermostat_v1.0 - device information
Manufacturer: Vimar
Model: WheelThermostat_v1.0
Firmware version: 1.0.0_z
Device type: Router
Power source: Mains
Endpoint 10
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- HvacThermostat (513)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
ZigBee app has been updated with new profiles and new helper functions for scripting.
These functions allow reading/writing device attributes and can be used to implement functionality that is not available in built-in profiles. Documentation: https://kb.logicmachine.net/libraries/zi...dattribute
Hello, the below mentioned thermostat, is this a unit that won't be supported?
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657
Manufacturer: Schneider Electric Model: EKO07259 Firmware version: 001.000.029 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - HvacThermostat (513) - HvacUserInterfaceCfg (516) - HaDiagnostic (2821) - ManuSpecificWiserEvent (65027) - ManuSpecificCycleTime (65302) - ManuSpecificHeatingCooling (65315) Output clusters - Identify (3) - Time (10) - Ota (25) - MsTemperatureMeasurement (1026) - MsOccupancySensing (1030) Endpoint 2 Profile: 260 Input clusters - Basic (0) - Identify (3) - MsTemperatureMeasurement (1026) Output clusters - Identify (3) Endpoint 3 Profile: 260 Input clusters - Basic (0) - Identify (3) - MsTemperatureMeasurement (1026) Output clusters - Identify (3) Endpoint 5 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - SeMetering (1794) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33)
is it possible to update Firmware for LSS100400 ? or is there no need for ?
Yes there is, if there will be a new firmware you will see this in the app.
I have 1 Tradfri bulb that works just as expected, both value status and onoff status. All good. Also RGB (and perfect RGB-status, thanks to admin!)
So when I got that one working, I bought a bunch of Philip Hue bulbs, thought they would for sure work. Except that they dont... I have four different kinds, and neither of them give status. If I go to "Control & status" on the zigbee page and click "Read" on device status, then the group adresses are updated correctly. But not from me sending on/off or brightness value.
I don't quite understand what I'm doing wrong, since I'm sure "everyone" has these bulbs... They are all listed here: https://kb.logicmachine.net/misc/zigbee-devices/ (except that manufacturer is "Signify Netherlands B.V." and not Philips, but I guess that goes for all of them). And the Tradfri works perfect...
Drop the device information from the zigbee app. If manufacture is different then it is a new device for us. All my Philips are Philips as manufacture.
(11.11.2024, 11:30)Daniel Wrote: Drop the device information from the zigbee app. If manufacture is different then it is a new device for us. All my Philips are Philips as manufacture.
That's weird...
Manufacturer: Signify Netherlands B.V. Model: LWE007 Firmware version: 1.76.10 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 11 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - LightLink (4096) - 64514 Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 0 - level: 127 - onoff: false - prevlevel: 127
Manufacturer: Signify Netherlands B.V. Model: LWA021 Firmware version: 1.78.1 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 11 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - LightLink (4096) - 64514 Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 38 - level: 38 - onoff: true - prevlevel: 38
Manufacturer: Signify Netherlands B.V. Model: LWE004 Firmware version: 1.76.10 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 11 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - LightLink (4096) - 64514 Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 0 - level: 254 - onoff: false - prevlevel: 254
Manufacturer: Signify Netherlands B.V. Model: LTA005 Firmware version: 1.78.1 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 11 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - LightLink (4096) - 64514 - LightingColorCtrl (768) Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33)
Hello.
Trying to integrate GU10 RGB Lights from EMOS (Legrand). Device is being detected as "TuYa - LED Strip Controller (RGB/CCT)". Everything seems works fine except one thing. Once lamp is added to LM/Apple Home, I am unable to set it to full brightness as it was before pairing. It do reacts on brightness control in Apple Home or from LM zigbee interface but it is not so bright as I would like to (as before pairing). Why?
Most likely now lights allows you to control only RGB or CT not both. When you turned it on, all were on.
Thanks Daniel.
Is there any chance to gain full control over this bulb?
Hi Daniel!
Is the change of manufacturer name the reason that my status GA's are not updating? If so, can I assume this will be fixed in the next app version sometime? Smile
