ekey fsx App
#41
(20.05.2023, 13:21)balatis Wrote: Hi
i have a problem with e key app , i can not find the scaner and when running the ekey app my cpu is very hi...
The device is LM 5 lite , firmwear Version: 20230420
The modbus port id tested and is ok
The wire is tested and is ok
i attached a foto from cpu load
Thanks in advance...
Hi,    I upgraded my LM 5 Lite to firmware v. 20230420.  ekey fsx app work the same way.
OK, which are the following steps, because it also creates an issue in fingerprint recognition?
Thank you.
The problem occurred because all the ekey db tables were lost in the LM local storage.
I couldn't repeat this problem on my LM5 Lite device by upgrading the firmware to v.20230420.
Correction algorithm to restore the functionality was:
1. Perform lua script:
os.execute("rm /home/apps/store/daemon/ekey/version")
2. restart the LM device or stop/start ekey fsx app daemon. The ekey fsx app daemon will create the new db tables for ekey fsx app.
3. select one of the scanners and perform cmd "SyncToDB" to restore fingerprints.
4. manually restore all other configuration.
Hello everyone,
Having not received a response to my private message, I decided to reach out to fellow members of this community for advice, just in case. We need licenses for several eKey scanners. I contacted user @Agris about this matter, and he responded fairly quickly to my private message. However, after a few clarifications exchanged between us, Agris suddenly (for me) “disappeared” – he has not responded to my latest messages, and the question regarding the licenses remains “hanging,” even though it has been more than three weeks. Judging by the activity data, @Agris has not logged into the LM forum at all since our last contact. He might be having some issues. We have an alternative solution, but before opting for it, I wanted to ask for your advice in this forum thread: are there any other ways to contact the developers of the eKey module for LogicMachine?
I would appreciate any useful opinions.
Ruta
(02.10.2024, 11:40)artlife Wrote: Hello everyone,
Ruta
Dear Ruta,
It seams you have not received my email I sent from 10.sept.
Today I send you it again to prieglauda@sosgyvunai.lt
Agris
New "ekey FSX app" v.20241010 is available for download:
http://www.avu.lv/logicmachine/ekey-app/...241010.ipk
User manual:
http://www.avu.lv/logicmachine/ekey-app/...manual.pdf
Changes from v. 20221203:
Find other type of ekey FSX scanners (like MyGekko FSX) and register with name 'Type: Unknown ekey fsx scanner'
Terminate ekey daemon process if the rs485 port can't be found or is broken. The problem was increased CPU = 99%.
Thanks you @agris
