Zigbee gateway integration
Yes no data corruption. It was not us, SE did it. In our app it is as stated in our documentations.
(16.11.2024, 11:45)stianj Wrote:
(15.11.2024, 13:16)admin Wrote: @stianj, enable debug logging in ZigBee app then reset and pair your lamp again. Send the logs afterwards.
Thanks. Logs attached. I enabled debug logging, deleted the bulb from the app, reset the bulb, opened the network, re-joined the bulb, configured all the GA's, then turned it on and off and changed brightness using the GA's.
The bulb in question has address 001788010b270b60
But result is still the same, the status GA's do not update unless I use "Read" on the Control and status page. This goes for all six Hue bulbs I have.
I can't quite see I'm doing anything wrong here, but I'm very open to you proving me otherwise Smile
I feel a bit ignored Angel
We identified the issue but it require some development on our side and it will take some unspecified amount time.
(20.11.2024, 10:42)Daniel Wrote: We identified the issue but it require some development on our side and it will take some unspecified amount time.
Thanks! That's fine, it's just nice to know that my issue is real - not just something I'm doing wrong, and also that you are working to fix it.
Appreciate it! Smile
Hello Daniel,
I am trying to read the rms current from a smart socket. But the code is not correct. Is it possible for you to give some guidance?
zb = require('applibs.zigbee.zigbee')
local address =  '70b3d52b600a3f9c'
endpoint = 3
cluster = 0x0B04 --
attrs = { 254 , 69 ,17, 401 }
-- Get rmscurrent from HaElectricalMeasurement cluster
local res, err = zb.cmdsync('getrawattribute', address, cluster, 401)
-- Log the result or the error
if err then
    log("Error retrieving rmscurrent: " .. err)
    log("RMS Current: " .. tostring(res))
Manufacturer: _TZ3000_okaz9tjs
Model: TS011F
Firmware version: 500+TZSKT31BS102
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- OnOff (6)
- Identify (3)
- Groups (4)
- Scenes (5)
- 57345
- HaElectricalMeasurement (2820)
- SeMetering (1794)
Reported attributes
- calclevel: 254
- currentsummdelivered: 665
- haactivepower: 69
- onoff: true
- prevlevel: 254
- rmscurrent: 401
- rmsvoltage: 241
(19.11.2024, 17:15)admin Wrote: Have you done reset and pair procedure after updating the app?
Yes i did it but no change
is it possible for 0-100 Scale to chose for DPT 5 or 9 ? in my case Gira S1 would use KNX DPT 9.007 for humdity and i cant record it with DPT 5
I use a VINDSTYRKA Air Qualitysensor and can only read the Value in 1byte DPT 5
(30.11.2024, 10:06)Sral1987 Wrote: Hi,
Try creating an event script for changing the value.
BR Cristian
Question. If I have a zigbee cluster list from a allready supported device, should I not be able to read or write to all attributes in the cluster by script?
Not all attributes are mandatory by the standard. Check the reply in ZigBee app monitor when you perform a read request.
Ok, I'll give it a go. I found some attributes for activating child safety, and sending external temperature to a thermostat.
(03.10.2024, 13:51)hepa Wrote:
(03.10.2024, 13:31)admin Wrote: There should not be any difference between heating and auto mode so that's why the control is binary.
We've only implemented most common features because we don't have the actual device to test the integration. Which other features are you missing?
That is not correct unfortunately. The auto mode is controlled by week timers and what not, the only functional mode on this heater is "Manual", where the heater is working after the given setpoint, so this is absolutely necessary for basic operation.
What we would like for our implementation is KeypadLockout and DisplayAutoOffActivation.
EDIT: As it is now, we have no way of setting the panel heater back to manual when the user changes to auto, neither any way to block local user input.
Soo... will there be a fix?
(Original post #500)
We plan to release an update this week which will add keypad lockout control via object. It will also contain a work-around for your device so System Mode is set to heat instead of auto when enabled.
DisplayAutoOffActivation can be set via a script. Make sure that ZigBee app is updated. Change addr as needed and run once:
zb = require('applibs.zigbee')
addr =  '1234567890abcdef'
cluster = 0x0201 -- Thermostat
attr = 0x1001 -- DisplayAutoOffActivation
value = 1 -- activated
dtype = 'enum8'
manufcode = 0x1224 -- Namron
res, err = zb.cmdsync('setrawattribute', addr, cluster, attr, value, dtype, manufcode)
log(res, err)
A new update has been published:
  • Added HVAC keypad lockout option
  • Added support for warning devices (sirens)
But no fix for the missing feedback from Hue-lamps, it seems. Am I the only one with Hue-lamps, or why isn't anyone else complaining? Wink
Did you reset and paired your lamps again after the upgrade? Try it and provide debug logs if it's still not working.
BR Cristian
This is my least favourit solution due to my lack of knwolage for lua scripting. Any hints here ? Smile
Map an event script to the source group address (DPT 5.001). Change 1/1/1 to the target group address (DPT 9.007).
grp.checkwrite('1/1/1', event.getvalue())
(11.12.2024, 13:10)admin Wrote: Did you reset and paired your lamps again after the upgrade? Try it and provide debug logs if it's still not working.
Wow, it actually worked! I tried before re-pairing the bulb, and still no feedback. But after re-paring (which I also tried on the earlier version) it now works.
Thank you! Was a bit fooled by the missing mention in the release notes...
I have of course two more issues I would like to ask...
1: I have bought a Hue Smart Plug (LOM007) which exposes dimming interface. Of course not a problem - I just don't have to use it - but is that a bug or intended behaviour?
Manufacturer: Signify Netherlands B.V.
Model: LOM007
Firmware version: 1.76.11
Device type: Router
Power source: Mains
Endpoint 11
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- LightLink (4096)
- 64514
Output clusters
- Ota (25)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- level: 254
- onoff: true
- prevlevel: 254
2: I have also just bought an IKEA Styrbar remote control. It has four buttons, but only two of them are exposed, as far as I can see? Is that intended? I see that HomeAssistant supports four buttons for this device.
Manufacturer: IKEA of Sweden
Model: Remote Control N2
Firmware version: 1.0.024
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- PollCtrl (32)
- LightLink (4096)
- 64599
Output clusters
- Identify (3)
- OnOff (6)
- LevelCtrl (8)
- Ota (25)
- LightLink (4096)
