somfy sonesse zigbee
I have this product and i want to control it with my LM.
with the Zigbee module the product are well recognized but it's impossible tio control the motor with the LM.
Do you have an idea how i can control this motor ?
THX
Hy Hocine,
I think you can ask admin on the forum, may be he can help to you attach this device to LM, but you need show here more info about your device's zigbee profile. Look zigbee on forum, hope will understand more. If your device also have RTS (additional connection for direct control - 4 wires needed - GND, Stop, Up and Down signals) or direct control just with powering wires - I can help you.
Somfy devices has at least 5 possible controlling solutions, it depends from model - direct with power (230V AC - 3 wires usually - N, L1 phase Up and L1 phase down signals), RTS - additional RJ-12 (6 pins, not RJ-45!!) for 6 wires, where 4 is used - (GND, stop, Up and Down). RS-485 - communication protocol (Modbus RTU), Zigbee you have or remote control. Please describe what you have onboard.
BR, Alex
(25.12.2024, 19:02)AlexLV Wrote: Hy Hocine,
BR, Alex
Thanks AlexLV  my Somfy motor are directly in zigbee, you can find the information here.
The product are recognize by the Zigbee app but the control don't work
https://www.somfysystems.com/en-us/produ...-dc-zigbee
Manufacturer: SOMFY
Model: Sonesse 30 DC 24V Roller
Firmware version: 5
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- ClosuresWindowCovering (258)
Endpoint 232
Profile: 260
Input clusters
- Basic (0)
- Ota (25)
Output clusters
- Basic (0)
- Ota (25)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Enable debug logs in ZigBee app configuration and post logs after controlling the device.
(27.12.2024, 09:15)admin Wrote: Enable debug logs in ZigBee app configuration and post logs after controlling the device.
here the log and the monitor
Nr,Time,Type,Address,Cluster,Action,Data
"16","10:40:09.768","RX 8%","000d6f00162c440a ","Ota","QueryNextImageRequest","FieldControl = 0, FileVersion = 34, ImageType = 8459, ManufacturerCode = 4619"
"15","10:39:51.413","RX","'- ","'-","zcl","fn = getnamedattributes, from = 4cc206fffe182b7f, result = [  ]"
"14","10:39:51.412","RX 64%","4cc206fffe182b7f ","ClosuresWindowCovering","ReadAttributesResponse","ReadAttributeStatusRecords = [ { AttributeIdentifier = 8, Status = CALIBRATION_ERROR }, { AttributeIdentifier = 9, Status = UNSUPPORTED_ATTRIBUTE } ]"
"13","10:39:51.342","TX","'- ","'-","zcl","addr = 4cc206fffe182b7f, args = [ 258, [ CurrentPositionLiftPercentage, CurrentPositionTiltPercentage ], 2 ], fn = getnamedattributes"
"12","10:39:49.947","RX","'- ","'-","zcl","fn = setwindowcovering, from = 4cc206fffe182b7f, result = 2"
"11","10:39:49.921","TX","'- ","'-","zcl","addr = 4cc206fffe182b7f, args = [ Stop ], fn = setwindowcovering"
"10","10:39:42.266","RX 60%","70b3d52b60012702 ","Basic","ReportAttributes","AttributeReports = [ { Attribute = { Type = uint8, Value = 100 }, AttributeIdentifier = 1 } ]"
"9","10:39:41.485","RX 65%","4cc206fffe182b7f ","ClosuresWindowCovering","DefaultResponse","CommandIdentifier = 1, Status = FAILURE"
"8","10:39:41.444","RX 64%","4cc206fffe182b7f ","ClosuresWindowCovering","ReportAttributes","AttributeReports = [ { Attribute = { Type = enum8, Value = 1 }, AttributeIdentifier = 1 } ]"
"7","10:39:41.289","RX","'- ","'-","zcl","fn = setwindowcovering, from = 4cc206fffe182b7f, result = 1"
"6","10:39:40.874","TX","'- ","'-","zcl","addr = 4cc206fffe182b7f, args = [ DownClose ], fn = setwindowcovering"
"5","10:39:35.592","TX","'- ","'-","getotastate","'-"
"4","10:39:35.592","RX","'- ","'-","getpermitjoin","addr = -1, max = 50"
"3","10:39:35.592","TX","'- ","'-","getpermitjoin","'-"
"2","10:39:35.591","RX","'- ","'-","gwdata","connmode = 10c4/bee0, fwversion = 20240710, ieeeaddr = 00124b002f8a9a15"
"1","10:39:35.590","TX","'- ","'-","getgwdata","'-"
the adress of the product and new log
4cc206fffe182b7f
.txt   logs (2).txt (Size: 43.47 KB / Downloads: 1)
Seems that a calibration procedure is needed for this device to work.
Run this script once and post what you get in LM Logs:
zb = require('applibs.zigbee')
res, err = zb.cmdsync('getnamedattribute', '4cc206fffe182b7f', 'ClosuresWindowCovering', 'Mode')
log(res, err)
(27.12.2024, 14:09)admin Wrote: Seems that a calibration procedure is needed for this device to work.
log(res, err)
here the log
"date","script","text"
"2024.12.27 21:16:31","initscript","* arg: 1
  * table:
  [""4""]
    * bool: false
  [""7""]
    * bool: false
  [""3""]
    * bool: false
  [""5""]
    * bool: false
  [""2""]
    * bool: false
  [""6""]
    * bool: false
  [""1""]
    * bool: false
  [""0""]
    * bool: false
* arg: 2
  * nil
Try enabling calibration mode:
value = {
  [1] = true, -- enable calibration
res, err = zb.cmdsync('setnamedattribute', '4cc206fffe182b7f', 'ClosuresWindowCovering', 'Mode', value)
log(res, err)
You might need to disable it afterwards for the device to operate properly. If this does not help then contact the device manufacturer support.
