status height - mosaic
Good morning,
I hope you are well.
We are facing an issue with status height in shutter vertical widget in Mosaic3.0.
Altghough the icon of the slats works properly, the slider doesn't respond to the correct position.
Firmware : LM5 lite - 20240219
Have we any solution about it?
Thank you in advance.
Can you share some screenshots what you have in mind exactly?
(23.01.2025, 08:33)Daniel Wrote: Can you share some screenshots what you have in mind exactly?
The icon in the black circle (the lines-slats) changes based on the status (when the roller is up, appears one line-slatĀ and when it is down, appears more lines-slats).
But the position of the circle-slider does not change.
Show me how did you map the objects and what are the values in the objects.
Here you are!
When a user moves a roller with the buttons up/down in the widget (and not via the slider-height), then the icon inside updates its value showing more or less lines, but the position of the slider-circle remains in the same position.
Only if you close-refresh the app or change room and enter again, the slider appears the right position.
Try writing manually value to feedback object and monitor the widget. It works for me.
Cloud was updated, should work now.
