27.01.2025, 09:52
hello guys i have a new problem with my lm each time i try save a change at widget in mosaic the lm rebot .
does that happend to anyone before
Lm rebooting after mosaic change
27.01.2025, 09:52
27.01.2025, 10:13
27.01.2025, 10:19
This is your problem, Mosaic has a design issue and it is limited to few MBs of custom images. The limit is around 8-9MB but each time you use even same custom image it is still counted as new and added to the total. Run this script once, it will move all custom images to LM images and replace yours with url. The issue with such solution is that you will not see images from cloud. This will fix your project and if you still want to use custome images also in cloud then make the size as small as possible.
Code: require('json')
require('encdec')
mosaickey = 'mosaic30:config:0'
config = storage.exec('get', mosaickey)
-- config = io.readfile('mosaic-backup.json')
config = json.pdecode(config)
icons = {}
relpath = '../../../../scada/resources/icons/'
abspath = '/www/scada/resources/icons/'
function fixicon(tbl)
local file = tbl.file
if type(file) ~= 'string' then
return
if file:sub(1, 10) ~= 'data:image' then
return true
local hash = encdec.md5(file)
if not icons[ hash ] then
local poss = file:find('/')
local pose = file:find(';')
local posd = file:find(',')
local ext = file:sub(poss + 1, pose - 1)
local filename = hash .. '.' .. ext
local data = encdec.base64dec(file:sub(posd + 1))
io.writefile(abspath .. filename, data)
icons[ hash ] = relpath .. filename
tbl.file = icons[ hash ]
return true
function fixstruct(tbl)
for key, val in pairs(tbl) do
if type(val) == 'table' then
if not fixicon(val) then
fixstruct(val)
fixstruct(config.floors)
fixstruct(config.imported_widgets)
config.custom_icons = icons
config = json.encode(config)
storage.exec('set', mosaickey, config)
Ctrl+F5 (27.01.2025, 10:19)Daniel Wrote: This is your problem, Mosaic has a design issue and it is limited to few MBs of custom images. The limit is around 8-9MB but each time you use even same custom image it is still counted as new and added to the total. Run this script once, it will move all custom images to LM images and replace yours with url. The issue with such solution is that you will not see images from cloud. This will fix your project and if you still want to use custome images also in cloud then make the size as small as possible. is there any way at least to the cloud to be viseble the deafult icons ??
30.01.2025, 13:59
Default icons will stay, only custom icons.
30.01.2025, 14:37
30.01.2025, 14:41
I'm not sure if I fully understand you. A widget/element can have one icon. It cannot be one locally and another in cloud.
30.01.2025, 14:44
