20.12.2024, 11:40
No input about these? Mostly interested in a way to use the left/right arrows on the IKEA Styrbar - I had plans for those...
Zigbee gateway integration
20.12.2024, 11:40
20.12.2024, 11:49
Custom actions for buttons can be done via a script: https://kb.logicmachine.net/libraries/zi...al-devices
Check ZigBee app monitor on what is sent when a certain button is pressed.
I just got a new hue strip, it won't be added in app. When i set network in open state, it disconnects the rs232 gw it seems. Button for network state dissappears and only a red flashing light on top right corner. Any ideas?
It seems, in monitor, that the gw finds the light, but just wont add it to the list. # Time Type Address Cluster Action Data 36 20:41:12.565 RX 14% 086bd7fffeb6c6cb ClosuresDoorLock ReportAttributes AttributeReports = [ { Attribute = { Type = enum8, Value = 2 }, AttributeIdentifier = 0 } ] 35 20:40:43.376 RX - - getpermitjoin addr = -1, max = 50 34 20:40:43.374 RX - - ready connmode = rs232, fwupgrade = false, fwversion = 20221226, ieeeaddr = 00124b00258c4ffa 33 20:40:36.921 RX 14% 086bd7fffeb6c6cb ClosuresDoorLock ReportAttributes AttributeReports = [ { Attribute = { Type = enum8, Value = 1 }, AttributeIdentifier = 3 } ] 32 20:40:35.630 RX - - init - 31 20:40:15.538 RX 54% 001788010c5678ec LightingColorCtrl ReadAttributesResponse ReadAttributeStatusRecords = [ { Attribute = { Type = uint16, Value = 366 }, AttributeIdentifier = 7, Status = SUCCESS } ] 30 20:40:15.519 RX 54% 001788010c5678ec LightingColorCtrl ConfigureReportingResponse AttributeStatusRecords = [ { Status = SUCCESS } ] 29 20:40:15.320 RX 54% 001788010c5678ec LevelCtrl ReadAttributesResponse ReadAttributeStatusRecords = [ { Attribute = { Type = uint8, Value = 254 }, AttributeIdentifier = 0, Status = SUCCESS } ] 28 20:40:15.319 RX 54% 001788010c5678ec LevelCtrl ConfigureReportingResponse AttributeStatusRecords = [ { Status = SUCCESS } ] 27 20:40:15.048 RX 54% 001788010c5678ec OnOff ReadAttributesResponse ReadAttributeStatusRecords = [ { Attribute = { Type = bool, Value = true }, AttributeIdentifier = 0, Status = SUCCESS } ] 26 20:40:15.006 RX 54% 001788010c5678ec OnOff ConfigureReportingResponse AttributeStatusRecords = [ { Status = SUCCESS } ] 25 20:40:14.811 RX 54% 001788010c5678ec Basic ReadAttributesResponse ReadAttributeStatusRecords = [ { Attribute = { Type = string, Value = 1.122.2 }, AttributeIdentifier = 16384, Status = SUCCESS } ] 24 20:40:14.809 RX 54% 001788010c5678ec Basic ReadAttributesResponse ReadAttributeStatusRecords = [ { Attribute = { Type = uint8, Value = 0 }, AttributeIdentifier = 3, Status = SUCCESS }, { Attribute = { Type = string, Value = Signify Netherlands B.V. }, AttributeIdentifier = 4, Status = SUCCESS }, { Attribute = { Type = string, Value = LCL001 }, AttributeIdentifier = 5, Status = SUCCESS } ] 23 20:40:14.408 RX 001788010c5678ec - announce ieeeaddr = 001788010c5678ec, nwkaddr = 8124
27.12.2024, 09:13
App has been updated, see if it fixes RGB device pairing for you.
27.12.2024, 14:52
(20.12.2024, 11:49)admin Wrote: Custom actions for buttons can be done via a script: https://kb.logicmachine.net/libraries/zi...al-devices Thank you very much! I should have known this. Bonus question, though: Is this an ok way to do this? Code: if not zb then
02.01.2025, 10:08
Script looks ok.
02.01.2025, 11:29
07.01.2025, 12:46
Hello again. I've been scripting to read and write some attributes.
Command is as follows: res, err = zb.cmdsync('setrawattribute', 'a49e69fxxxxxx' , 513, 1043, true, 'bool') The command value "true" does as it should, but when writing "false" I get "No response". It's the same for all other 'bool' attributes. Is this component issue or zigbee app issue? Thanks in advance.
07.01.2025, 12:51
What do you have in the ZigBee app logs?
07.01.2025, 13:29
This is monitor data, not logs.
(07.01.2025, 13:29)admin Wrote: This is monitor data, not logs. ah, sorry. Log: Code: 2025-01-07 14:37:14 ZB: sending ZCL message to a49e69fffe7d394b, cluster 0201, dst EP 1: Code: 2025-01-07 14:37:14 ZB: could not encode ZCL data, error: /tmp/tmp.jOqIz9XAnc/files/store/daemon/zigbee/lib/codec.lua:315: no value for Value Code: 2025-01-07 14:39:41 ZB: sending ZCL message to a49e69fffe7d394b, cluster 0201, dst EP 1: when sending "true" it actually sends the value true. As far as I can see, that is not the case when false is transmitted.
09.01.2025, 11:35
Any feedback regarding this?
10.01.2025, 12:30
ZigBee app has been updated, see if it fixes the attribute writing issue for you.
12.01.2025, 15:28
(10.01.2025, 12:30)admin Wrote: ZigBee app has been updated, see if it fixes the attribute writing issue for you. Hello How can I be sure that my devıce received the latest update? Does SE Wiser have the same fix? Still ZigBee 3-channel switch, can not change chanels independently (https://community.home-assistant.io/t/zi...tly/501707) they solved the issue for ZHA but still in Wiser I cannot control independently 3 or 4 channel relay modules. Do you have the visibility on this issue? Thank you Best Regards Turker
13.01.2025, 08:51
SE is maintaining apps on their own, it is not question to us.
04.03.2025, 20:08
How do you add zigbee products? I read that you can add profiles but can't find where this can be done and where to find all the profiles? Is the reset button the small one at the top next to the diodes? I have a variety of schneider wiser products that are on the list
05.03.2025, 08:25
It is hard codded in the app, only we can add profiles.
05.03.2025, 10:29
