I identifed that when you use a pop up custom widget, there is a bug.
Before you open the pop up, everything works properly.
If you click to open the pop up, everything inside the pop up work properly.
But when you close the pop up, there is no control (or a difficulty to control) the elements that were covered by pop up.
01.04.2025, 18:02 (This post was last modified: 01.04.2025, 18:05 by Omega Technology.)
Hi, we have some issue with some widget in visu, let me explain better, the page loads and, without pressing anything, it seems that in the page there are some objects that are in the widgets themselves, which prevent you from clicking the icons on the page, I attach an example where you can see it in the html. best regards, Omega Technology. (Firefox browser 136.0.4)
(01.04.2025, 18:02)Omega Technology Wrote: Hi, we have some issue with some widget in visu, let me explain better, the page loads and, without pressing anything, it seems that in the page there are some objects that are in the widgets themselves, which prevent you from clicking the icons on the page, I attach an example where you can see it in the html. best regards, Omega Technology. (Firefox browser 136.0.4)
found the same thing today. looks like button consists of two part. One work correct, second do nothing. I move button and problem was solved.
Hi, I don't want to be pushy, have you received any bug reports? Is there a way to fix these problems? As you can see from the screenshot I don't have much space to move the icons that link to the widgets. Thanks
Using Firefox Mobile the tile-version is not working, I can't click on any of the buttons... Sliders work, but not buttons... Firefox on Desktop works fine (also in Tile view, and Chrome on mobile works fine... Weird.
If I make a Layout with a background, and then make a Plan and use that Layout, the background from the Layout is not showing!
Images and text added to the Layout shows just fine on the Plan.
Tested on Chrome and Firefox.
Don't forget that there is third place to define backgrounds, Global appearance, if Plan background is set there then it will have higher priority over Layout same parameter.
Replace group addresses in a widget, doesn't seem to be very helpful.
The new addresses will not always follow the same arrangement,
so I guess it would be more useful to replace each address separately.
You can always do it manually if the rules for object creations don't work. This will work only if you fallow the rules. We did it exactly the same as in ETS paste special.
Have you created the trend log recently? If so then try increasing trend widget view period to two or three days and see if you can replicate the issue.
