Mosaic fans in Home Page
I've got a costumer, who's like to have most of his widgets on his Home Page. That means the widgets/standard buttons leading directly to a floor+room gets at the very bottom of the page. This way he has to scroll all the way down to the "links" to the other rooms (and yes, he can use the menu tree, but apparently he doesn't want to "click so many times before enting af room). He can, though, replace all the widgets on the home screen down below the room-links, but he has experienced it "resets", and suddenly the links are in the buttom of the Home Page again.
1. Is this "reset" happening, when I'm editting the visualization/Mosaic?
2. Is it possible to get to drag/reposition the "links" to the top, instead of doing it to everything else on the page OR
2a. Is it possible to make the widget myself: "Go-To-Room", so that he can rearange that widget?
Or maybe another workaround?
The screen shot is of Mosaic when unlocked to rearrange widgets, but as visible; the link doesn't highlight as being able to be moved.
Thanks Smile
Do I'm right that you first created one room with widgets and then added them to main screen then you created more rooms?
The general order of widgets is on time of creation. I think if you remove all widgets from home screen and then add them back again the room links should stay on top.
But since there's only one (or two) room page he'd like on top, out of 8 room pages; can we do something fancy about that?
You could try this but it will work only locally
https://forum.logicmachine.net/showthrea...5#pid38245
If you set the link like this it will also work in cloud
window.location='/apps/data/mosaic30/#r/0/0';
Thanks a lot. I got it working! Smile
Hi again!
The costumer says the order of the widgets is not consistent. Now and then, when he opens the LM App, the order is back to as if it was never rearranged. I do believe the order is need to be set on each single device, but is it a known bug that it reaaranges or ??
When using the app make sure it's kept running in the background. Order changes will be lost if the app is killed right after changing the order.
So whenever the app is "forced" closed, the order is lost? Or does the app just need to be running to "save" the order?
It is the OS on your device which is saving the configuration, there is no specific time as long I'm aware. Just let the app running and it will be saved by OS.
