15.08.2025, 14:15 (This post was last modified: 15.08.2025, 14:16 by AlexLV.)
now I try to find out why I did not see picture in camera widget. I switched On local proxy usage, I checked login/pass is OK. I have I hikvision camera and using such link (for second video channel):
http://IP/Streaming/channels/102/picture
Local proxy can work with any pic resolution or exist some restriction?
May be also important other camera settings?
How can I check problems in local proxy working?
Size limit is 1MB so use lower snapshot resolution and lower JPEG quality. Does this URL work if you open it in browser? Is the camera in the same subnet as LM?
Same thing can be done with any other element. We don't want to make the customization too complex so we stick only to the most common parts.
Which title are you referring to? Top bar with plan name or tile view widget title?
Hi ,
For example, In tile view , if we add a switch we will use tile text to tell customer via tile text what is control purpose. Therefore tile text in tile view is important . We would like to customize more . If you split appearance menu in widget like tile appearance and general appearance , you can add font change menu of tile text in the tile appearance menu and it will be no complex in my opinion. I added 2 pictures for my suggestion to tell what i mean.
It's not that easy, certain settings apply to both views depending on the widget. There's a global setting that applies background and border to plan view widgets. We'll add some info text to make it more clear where these settings can be used.
Ok. Customizing tile text is a need. Please consider. Any kind of text we put on the plan or tile , we need to change font color as a beginning at least.
18.08.2025, 11:50 (This post was last modified: 18.08.2025, 11:52 by AlexLV.)
(15.08.2025, 14:19)admin Wrote: Size limit is 1MB so use lower snapshot resolution and lower JPEG quality. Does this URL work if you open it in browser? Is the camera in the same subnet as LM?
Hi, now all is working.
Customer have this camera - Hikvision DS-2CD2047G2H-LIU
Refresh interval is counted between full image loads. Some cameras are quite slow in providing snapshots. For example if the image takes 2 seconds to load and refresh interval is 3 seconds then the image will be refreshed every 5 seconds.
19.08.2025, 07:41 (This post was last modified: 19.08.2025, 08:08 by AlexLV.)
(19.08.2025, 07:28)admin Wrote: Refresh interval is counted between full image loads. Some cameras are quite slow in providing snapshots. For example if the image takes 2 seconds to load and refresh interval is 3 seconds then the image will be refreshed every 5 seconds.
Thank you for info.
Alex
Now I am experimenting with background pictures.
1. I took 270x180 pixels picture jpg type. 13.16Kb size. At my PC in visu admin all is OK, but at my phone still background not seen. I see category widget background, not putted in widget picture (in attach). So where could be problem with background pic?
2. May be needed correction in settings - if we will use background picture - background color should be set to transparent, or we still see background color not picture..
19.08.2025, 09:00 (This post was last modified: 19.08.2025, 09:01 by AlexLV.)
Ok, good, but what to do? Cache somewhere?
And at your pic still not seen temperature value in the middle of widget (white color used) and also not seen graph (should be white color and graph grid (gray color I used)..
