Retrieving Trend Data via periods.lp
Hello everyone,
I'm currently building a custom energy monitoring application on Lm5. I’ve successfully accessed real-time values using
grp.getvalue() and identified the key trends (energy, power, consumption, etc.).
Now I’d like to implement period-based calculations (daily, weekly, monthly, yearly) using the periods.lp file to track
energy consumption over time.
 My goal is to:
  • Store the trend index at midnight (e.g. for photovoltaic energy)
  • Compare it with the current index to calculate daily production
  • Extend this logic to weekly, monthly, and yearly periods
 Questions:
  1. What is the recommended way to store and retrieve trend indexes at specific timestamps (e.g. midnight) using
    periods.lp ?
  2. Is there a built-in API or LogicMachine function to manage periods and deltas?
  3. Should I create a custom structure inside periods.lp , or is there a standard format I should follow?
  4. Has anyone implemented similar logic for periodic energy calculations and could share best practices?
Thanks in advance for your help and insights!
https://kb.logicmachine.net/libraries/trends/
(04.09.2025, 07:23)Daniel Wrote: https://kb.logicmachine.net/libraries/trends/
Error in ./www/apps/data/compteur4multi/libs/compteur4multi.lua at line 45: attempt to index global 'storage' (a nil value)
i always have this issue and i don't understand my mistake
i have this at line 45
"dependencies": {
    "lua_modules": ["storage", "trend", "grp", "json"],
    "system_version": ">=2.5.0"
What is your full script?
I have a file app.json
  "id": "compteur4multi",
  "title": "Compteur Multi-énergies",
  "version": "1.0.0",
  "author": "Schneider Electric",
  "description": "Calculs d'autoconsommation et d'autonomie photovoltaïque",
  "category": "energy",
  "tags": ["energy", "photovoltaic", "consumption", "monitoring"],
  "icon": "icon.svg",
  "main": "index.lp",
  "config": "config.lp",
  "permissions": {
    "storage": true,
    "trends": true,
    "groups": true,
    "scripts": true
  "files": [
    "index.lp",
    "config.lp",
    "style.css",
    "compteur4multi.js",
    "icon.svg",
    "api/compute.lp",
    "api/config_save.lp",
    "api/periods.lp",
    "api/diag.lp",
    "libs/compteur4multi.lua",
    "libs/utils.lua"
  "dependencies": {
  "installation": {
    "create_resident_script": true,
    "script_name": "compteur4multi_resident"
