Modbus profiler app
#21
Are you rebooting LM via UI? If you reboot via power cycle then the latest changes might be lost.
As for you previous questions - the possibility to edit existing devices is not meant to be a replacement for the main Modbus UI. It is implemented to tweak the profile instead of making a new device from scratch if any mistakes are found. That's why proper object selection is not implemented.
If you edit custom values for an existing device nothing will happen until you map a new object via main Modbus UI.
Hmm, yeah, it was power cycled.
I had last changed the modbus profile in end of July (about same time as my previous post in this thread). After that date, I have both clicked "Save project", updated to the new beta firmware, and saved project backup (have not tried to restore, but would expect it to also be wrong then?)
The power cycling happened this weekend.
What can I do to make sure my modbus settings are not lost in case of a power outage?
What kind of changes did you make in July?
Sorry, I have not been able to reproduce this (and I've tried!), so don't know what happened, but it must have been some kind of coincidence. Sorry for the noise!
