Reactor LTE problem
Hi guys
I received my LogicMachine5 Reactor LTE last Friday and I'm trying to get the LTE connection up and running before sending it out to our customer.
I followed the instruction you posted to another customer with a similar problem, and got these results:
* arg: 1
  * string: open port
* arg: 2
  * string: /dev/ttyUSB2
* string: AT&F
OK
+CPIN: SIM PIN
ATE1
OK
AT+CGDCONT=1,"IP","internet"
ERROR
ATD*99***1#
ERROR
And ran the other script to check signal strength i assume?
* string: Signal: 29
* string: SIM: unknown
* string: Network: no info
Am I missing something?
Remove PIN code protection from the SIM card and try again.
(27.05.2024, 10:03)admin Wrote: Remove PIN code protection from the SIM card and try again.
Thank you, that worked
1 more question!
How do I configure ZeroTier without setting a Gateway IP?
ZeroTier needs internet access so it won't work without a gateway/DNS. When 3G/4G connection becomes active it will override the default gateway so all external traffic is routed via the mobile network.
(27.05.2024, 13:29)admin Wrote: ZeroTier needs internet access so it won't work without a gateway/DNS. When 3G/4G connection becomes active it will override the default gateway so all external traffic is routed via the mobile network.
Does that mean that I can't use ZeroTier?
I waited until I could see my 4G IP under 3G/4G settings, then I clicked on ZeroTier and it came with a red message that I need a Gateway IP before I can use ZeroTier!
It will work, but you need to set gateway and DNS in Ethernet settings. Otherwise you will get this error message.
(27.05.2024, 15:57)admin Wrote: It will work, but you need to set gateway and DNS in Ethernet settings. Otherwise you will get this error message.
Perfect, can I set my sim cards IP as gateway? and just use google as DNS?
Set proper gateway for the local network. You can use Google DNS.
When the mobile network is connected the default gateway will switch to the mobile network automatically.
You need to set gateway in Interface eth0 configuration. This won't affect 3G/4G connectivity.
(27.05.2024, 10:02)BMSimon Wrote: Hi guys
* arg: 1
  * string: open port
* arg: 2
* string: AT&F
OK
+CPIN: SIM PIN
ATE1
OK
ERROR
ATD*99***1#
ERROR
Good evening,
i come back on this post, anyone can share with me the script to have the LTE signal power?
Best regards Cristian Grassi
Hi Cristian,
not remember all details now, but I added to my modem script's this part (in incoming sms handler):
-- incoming sms handler
  readcsq = function()
    local res, err, reply = modem:send('AT+CSQ')
    local rssi
    if reply then
      rssi = reply:match('%+CSQ:%s+(%d+),(%d+)')
    rssi = tonumber(rssi) or 0
    if 2 <= rssi and rssi <= 9 then
      quality = 'marginal'
    elseif 10 <= rssi and rssi <= 14 then
      quality = 'ok'
    elseif 15 <= rssi and rssi <= 19 then
      quality = 'good'
    elseif 20 <= rssi and rssi <= 30 then
      quality = 'excellent'
      quality = 'unknown'
    grp.write('0/0/40', quality)  -- Modem signal level write to group
For modem I use resident script, working every 10 seconds.
Hope it helps.
If not - I will look deep and will write my modem's script and info. I have 2G BGS2T modem, connected to usb on LM through USB2RS232 adapter. Working already ~8 years without problems.
Alex
(06.11.2025, 20:07)AlexLV Wrote: Hi Cristian,
    local rssi
    if reply then
      quality = 'ok'
      quality = 'good'
      quality = 'unknown'
Hope it helps.
Alex
Thanks I will check.
