20.11.2025, 09:22
Is there any chance that i could set the alerts to pop up in visu as like it was possible in visualization?
Alerts like visualization
20.11.2025, 09:22
20.11.2025, 09:27
Add to Custom JavaScript (three dots menu in the top right corner):
Code: localbus.listen('alerts', (src, text) => alert(text))
20.11.2025, 09:35
20.11.2025, 12:25
Hi, is it works locally? In any browser?
Is somehow possible create an alert using cloud and be seen at mobile? Alex
20.11.2025, 12:41
This will only work locally not via cloud. We plan to create a more complex alerting system that will have cloud connectivity.
Instead of using built-in alerts you can use a virtual object with 250 byte text data type. For this to work over cloud you either need to have this object displayed on any visu plan or assign lmcloud tag to this object. Code: localbus.listen('groupwrite', (e) => {
20.11.2025, 14:55
Hi, I created group 0/0/14 with 250 byte text data type. I also displayed on new visu (beta) plan and also assigned lmcloud tag to this group, and added to Custom JavaScript your script, updated visu. Still working only locally.
Alex
21.11.2025, 07:41
Sync cloud and try again.
29.01.2026, 15:05
Is there a way to pop up embedded alert page in visu via frame like old visu ? I mean , like Persistent option in old frame usage ?
29.01.2026, 15:52
Persistent iframe is not possible in new Visu. But it should be possible to make a solution using Custom JS. Something like a floating button that shows Alert manager frame when clicked.
