28.11.2025, 08:26
Can you post full device information window output for both devices?
Zigbee gateway integration
28.11.2025, 08:26
28.11.2025, 08:32
(28.11.2025, 08:26)admin Wrote: Can you post full device information window output for both devices? Sure, here it is: Manufacturer: SONOFF Model: SNZB-02LD Firmware version: 1.1.0 Device type: End device Power source: Battery Receive when idle: No Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - MsTemperatureMeasurement (1026) - PollCtrl (32) - 64599 - 64529 Output clusters - Ota (25) Reported attributes - temperature: 17.20 Manufacturer: BOSCH Model: RBSH-SP-ZB-EU Firmware version: 2.5 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - SeMetering (1794) - HaElectricalMeasurement (2820) - HaDiagnostic (2821) Output clusters - Identify (3) - Time (10) - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 0 - currentsummdelivered: 0 - haactivepower: 0 - hapowerdivisor: 1 - hapowermultiplier: 1 - onoff: false - prevlevel: 254 - sepowerdivisor: 100 - sepowermultiplier: 1
01.12.2025, 18:27
I have bought a Heiman WarningDevice-EF-3.0, which is in the supported list devices. But I only get "detection" and "low battery detected" which are not useful. Maybe is because I have a Wiser for Knx?, I have the last firmware update. Here is the info:
Manufacturer: HEIMAN Model: WarningDevice-EF-3.0 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - Groups (4) - SsIasZone (1280) - SsIasWd (1282) - HaDiagnostic (2821) Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - detection: false
02.12.2025, 09:39
SE is updating Zigbee app on its own, our list may not match what is supported by SE. Detection seems the only thing this device reports. What else would you want from this sensor?
02.12.2025, 17:54
03.12.2025, 09:04
OK I thought it is a smoke detector, still you should contact SE.
04.12.2025, 12:12
I just bought an IKEA Inspelning smart plug with energy meter. It's not in the list of supported devices, I know. But it joins just fine, and under configure I have both "RMS Voltage", "RMS Current" and "Energy delivered". All good! Except that the values don't update unless I read device status manually. Then it's updated.
Code: Manufacturer: IKEA of Sweden(And it's a bit weird with dimming properties on a on/off socket - but that's not really a problem)
04.12.2025, 12:58
(04.12.2025, 12:12)stianj Wrote: I just bought an IKEA Inspelning smart plug with energy meter. It's not in the list of supported devices, I know. But it joins just fine, and under configure I have both "RMS Voltage", "RMS Current" and "Energy delivered". All good! Except that the values don't update unless I read device status manually. Then it's updated. Hi, Have you tried rejoining it to the zigbee network, that helped for me. Greetz, Tigi
04.12.2025, 13:01
Voltage/current/power reporting won't work without a profile. Some devices will report values automatically but most devices won't send reports unless the gateway subscribes to them.
04.12.2025, 13:15
Yeah, I suspected so. So... will you pretty please consider adding it in the next version..?
08.12.2025, 13:09
New app version has been published. Added support for Ikea INSPELNING Smart plug, BOSCH RBSH-SP-ZB-EU and SONOFF SNZB-02LD. Please reset your devices and pair them again.
08.12.2025, 17:02
Thank you very much! Works perfect
08.12.2025, 17:55
Hi Admin,
Thanks for the update! Greetz, tigi
hello,
I have smoke detector Aqara sd-s01e but when smoke detection i don't have the detection object knx change. any idea ? need to ask the detector by script ? AttributeIdentifier = 5, Type = "string", Value = "lumi.sensor_smoke.acn03" Xiaomi/Aqara (modèle acn03) ManufacturerCode = 4447 et le ClusterId = 64704 ou 0xFCC0 AttributeIdentifier = 247 (ou 0xF7 en hexadécimal, souvent utilisé par Xiaomi pour les données multi-attributs) Value = [62] 01 21 **3D 0B** 03 28 19 IAS Zone Status (Cluster 0x0500, Attribut 0x0002) IAS Zone (0x0500)
FRANCE SMARTHOME & SMARTBUILDING INTEGRATION SE ECO EXPERT
11.12.2025, 07:56
