Zigbee gateway integration
Can you post full device information window output for both devices?
(28.11.2025, 08:26)admin Wrote: Can you post full device information window output for both devices?
Sure, here it is:
Manufacturer: SONOFF
Model: SNZB-02LD
Firmware version: 1.1.0
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- MsTemperatureMeasurement (1026)
- PollCtrl (32)
- 64599
- 64529
Output clusters
- Ota (25)
Reported attributes
- temperature: 17.20
Manufacturer: BOSCH
Model: RBSH-SP-ZB-EU
Firmware version: 2.5
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- SeMetering (1794)
- HaElectricalMeasurement (2820)
- HaDiagnostic (2821)
Output clusters
- Identify (3)
- Time (10)
- Ota (25)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 0
- currentsummdelivered: 0
- haactivepower: 0
- hapowerdivisor: 1
- hapowermultiplier: 1
- onoff: false
- prevlevel: 254
- sepowerdivisor: 100
- sepowermultiplier: 1
I have bought a Heiman WarningDevice-EF-3.0, which is in the supported list devices. But I only get "detection" and "low battery detected" which are not useful. Maybe is because I have a Wiser for Knx?, I have the last firmware update. Here is the info:
Manufacturer: HEIMAN
Model: WarningDevice-EF-3.0
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- Groups (4)
- SsIasZone (1280)
- SsIasWd (1282)
Output clusters
- Ota (25)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- detection: false
SE is updating Zigbee app on its own, our list may not match what is supported by SE. Detection seems the only thing this device reports. What else would you want from this sensor?
(02.12.2025, 09:39)Daniel Wrote: SE is updating Zigbee app on its own, our list may not match what is supported by SE.  Detection seems the only thing this device reports. What else would you want from this sensor?
It is a siren, i want to activate the siren as an alarm.
OK I thought it is a smoke detector, still you should contact SE.
I just bought an IKEA Inspelning smart plug with energy meter. It's not in the list of supported devices, I know. But it joins just fine, and under configure I have both "RMS Voltage", "RMS Current" and "Energy delivered". All good! Except that the values don't update unless I read device status manually. Then it's updated.
Manufacturer: IKEA of Sweden
Model: INSPELNING Smart plug
Firmware version: 2.4.45
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- SeMetering (1794)
- LightLink (4096)
- 64636
- 64645
Output clusters
- Ota (25)
Endpoint 242
Profile: 41440
Input clusters
- GreenPower (33)
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- currentdivisor: 1000
- currentmultiplier: 1
- currentsummdelivered: 0.4
- hapowerdivisor: 10
- haactivepower: 192.4
- level: 254
- onoff: true
- prevlevel: 254
- rmscurrent: 0.9
- rmsvoltage: 230.4
- sepowerdivisor: 1000
- voltagedivisor: 10
- voltagemultiplier: 1
(And it's a bit weird with dimming properties on a on/off socket - but that's not really a problem)
(04.12.2025, 12:12)stianj Wrote: I just bought an IKEA Inspelning smart plug with energy meter. It's not in the list of supported devices, I know. But it joins just fine, and under configure I have both "RMS Voltage", "RMS Current" and "Energy delivered". All good! Except that the values don't update unless I read device status manually. Then it's updated.
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- SeMetering (1794)
- LightLink (4096)
- 64636
- 64645
Output clusters
- Ota (25)
Endpoint 242
Profile: 41440
Input clusters
- GreenPower (33)
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- level: 254
- onoff: true
- prevlevel: 254
- rmscurrent: 0.9
- rmsvoltage: 230.4
Have you tried rejoining it to the zigbee network, that helped for me.
Greetz,
Tigi
Voltage/current/power reporting won't work without a profile. Some devices will report values automatically but most devices won't send reports unless the gateway subscribes to them.
Yeah, I suspected so. So... will you pretty please consider adding it in the next version..?  Angel
New app version has been published. Added support for Ikea INSPELNING Smart plug, BOSCH RBSH-SP-ZB-EU and SONOFF SNZB-02LD. Please reset your devices and pair them again.
Thank you very much! Works perfect Smile
Hi Admin,
Thanks for the update!
Greetz,
tigi
hello,
I have smoke detector Aqara sd-s01e
but when smoke detection i don't have the detection object knx change.
any idea ?
need to ask the detector by script ?
AttributeIdentifier = 5, Type = "string", Value = "lumi.sensor_smoke.acn03"
Xiaomi/Aqara (modèle acn03)
ManufacturerCode = 4447 et le ClusterId = 64704 ou 0xFCC0
AttributeIdentifier = 247 (ou 0xF7 en hexadécimal, souvent utilisé par Xiaomi pour les données multi-attributs)  Value = [62] 01 21 **3D 0B** 03 28 19
IAS Zone Status (Cluster 0x0500, Attribut 0x0002)
IAS Zone (0x0500)
SE ECO EXPERT
See this: https://forum.logicmachine.net/showthrea...2#pid40162
(11.12.2025, 07:56)admin Wrote: See this: https://forum.logicmachine.net/showthrea...2#pid40162
i saw it. But i was thinking with script a possibility to update it.
I tried:
if not zb then
  zb = require('applibs.zigbee.zigbee')
  local address = '54ef441000d98b22' -- Adresse IEEE de votre détecteur de fumée
  cluster = 0xFCC0 -- Cluster IAS Zone (Alarme de Sécurité) 1280
  attrs = { 0x0002 }-- Get rmscurrent from HaElectricalMeasurement cluster
  local res, err = zb.cmdsync('getrawattribute', address, cluster, 295 ) -- 0x0002 est l'Attribut Zone Status
  -- Log the result or the error
  if err then
      log("Error retrieving val: " .. err)
      log("Val: " .. tostring(res))
script.disable(_SCRIPTNAME)
without luck
So your point is that i should change them ? there will be no support in futur ?
SE ECO EXPERT
You can't read most battery powered device this way. The device is sleeping most of the time and won't receive any messages.
This particular sensors is broken and won't be supported.
You are using SE app version which is not developed by us. I doubt that they have any interest in supporting third party devices.
yes SE is blocking lots of cool stuf...
ok so i will change them !
SE ECO EXPERT
SE indeed blocks cool and useful stuff.
I have a Namron 4512784 thermostat that I don't think is fully supported by either LM or SE.
the readout is:
Manufacturer: Namron AS
Model: 4512784
Firmware version: 1.12
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- HvacThermostat (513)
- HvacUserInterfaceCfg (516)
- MsRelativeHumidity (1029)
- SeMetering (1794)
- LightLink (4096)
- 57346
Output clusters
- Identify (3)
- Ota (25)
- MsOccupancySensing (1030)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- currentdivisor: 1
- currentsummdelivered: 21.4
- hapowerdivisor: 1
- humidity: 45.0
- haactivepower: 0
- localtemperature: 22.00
- occupiedheatingsetpoint: 21.50
- onoff: true
- picoolingdemand: 0
- piheatingdemand: 0
- prevlevel: 254
- rmscurrent: 0
However, if I read from the hybrid app for device status and control I see the following:
Device status
OnActive power: 0.0WRMS current: 0.00AEnergy delivered: 30.20kWhKeypad lockout: 1
So there is information/objects there, I just cannot map it correctly in the hybrid app. Is it possible to extract setpoint and energy delivered via script somehow?
Check this: https://kb.logicmachine.net/libraries/zi...-attribute
For Voltage/Current/Power the formula is value * Multiplier / Divisor. In most cases multiplier and divisor are fixed values.
