10 hours ago
Hello everyone,
I have several air handling units connected behind an RS485-to-IP module, using the Modbus RTU protocol. As a result, there are no communication errors with the IP module itself; however, communication errors may occur on the air handling units connected downstream.
For example, if one air handling unit experiences a communication fault, this is correctly recorded in the error log within the Modbus tab. I would like to know whether there is a way to propagate or retrieve this error in order to trigger an email notification.
Best regards.
Best regards.
