LM5 i.MX6Y1 (UltraLite) Firmware
Happy new Year!
Since the SD card in my LM was defective, I replaced it and installed the recovery image. Now I need the image for the i.MX6Y1 (UltraLite) CPU. Can anyone send me the link to download it? Unfortunately, I couldn't find it on the website.
Many Thanks!
Firmware: https://logicmachine.net/downloads#firmware
Recovery image: https://kb.logicmachine.net/misc/reflash...the-device
(01.01.2026, 11:42)admin Wrote: Firmware: https://logicmachine.net/downloads#firmware
Thank you for your message, but I was unable to find the appropriate image in this list. (imx6ul needed)
The https://dl.openrb.com/lm-24-imx6/lm5m3-20240426.img image does not boot!
Thanks!
Have you flashed the recovery image first? Does it boot?
(02.01.2026, 07:59)admin Wrote: Have you flashed the recovery image first? Does it boot?
Hello admin
Q: Have you flashed the recovery image first?
A: Yes, I have. I can access the Recovery website under 192.168.0.10 for uploading the actual image. So far, so good. But now I need the right image for the CPU installed in my device.  i.MX6Y1 (UltraLite)
I uploaded the following image:
However, after uploading, the device was inaccessible, so I flashed the recovery image again.
I can't find it in the download area. (i.MX6UL)
Where can I download them?
Thanks!
iMX6 firmware is common for all CPU models. Try 2025 RC3 firmware: https://forum.logicmachine.net/showthread.php?tid=6213
If it doesn't work then maybe there is a another hardware problem, not only with the card.
(02.01.2026, 12:53)admin Wrote: iMX6 firmware is common for all CPU models. Try 2025 RC3 firmware: https://forum.logicmachine.net/showthread.php?tid=6213
Thank you for your message.
I downloaded and installed the new image. Now the device is completely dead again. No LED, no network link, nothing. It won't boot up, so I have to assume that this image does not work for my device/CPU.
You should have mentioned that your device is not LM earlier. Use a relevant firmware provided by the manufacturer. LM firmware won't work.
(02.01.2026, 17:19)admin Wrote: You should have mentioned that your device is not LM earlier. Use a relevant firmware provided by the manufacturer. LM firmware won't work.
I purchased the device with LM installed and received the original SD card with it. Now the SD card is defective and I would like to reinstall LM.
There is no LM firmware for LSS100200, never was. Where did you get it?
