Trends buttons
Is there any way to hide  butons "Graph/Data" and "Export trend data" in the trends page (not using iframe) dependeing on which user is logged?
I've tried something like this, but doesn't work:
if (window.Globals && Globals.user === 'user') {
    $('.trends .btn-group').addClass('hide');
    $('.trends .show-export').addClass('hide');
username is not exposed in Trends and Schedulers. One option is to hide these buttons for all users via CSS:
.trends .show-export,
.trends .inner .btn-group {
  display: none;
.trends .content > div {
  padding-bottom: 0;
There's a different solution using .lp script to determine the username but it cannot be used in LM cloud: https://forum.logicmachine.net/showthrea...20#pid6820
Hi, thanks!
As I don't need it using cloud I've solved using .lp file in the link you shared and this javascript:
  // Llistat d'usuaris que han de tenir hide
  var usuarisAmbHide = [
    'usuari',
    'visualitzacio',
    'demo'
  var xhttp = new XMLHttpRequest();
  xhttp.onreadystatechange = function () {
    if (xhttp.readyState === 4 && xhttp.status === 200) {
      var res = xhttp.responseText;
      res = res.trim();
      if (res !== undefined && res !== null) {
        // Comprovar si l'usuari està dins del llistat
        if (usuarisAmbHide.indexOf(res) !== -1) {
          document
            .querySelectorAll('.trends .btn-group, .trends .show-export')
            .forEach(function (el) {
              el.classList.add('hide');
          console.log('hide aplicat a l’usuari:', res);
  xhttp.open('GET', '/user/user.lp', true);
  xhttp.send();
