HTML Widget
I am using an HTML widget in Visui to build a custom table layout
using pure HTML + CSS.
Example (simplified):
<div class="rc-row rc-head">
  <div class="rc-cell">Room</div>
  <div class="rc-cell">Ambient Temp</div>
  <div class="rc-cell">Current Temp</div>
  <div class="rc-cell">HVAC Mode</div>
</div>
Rows are static HTML, used only as a layout grid.
I would like to display and control KNX group objects inside specific
cells of this HTML table.
Is it possible to bind KNX group objects directly inside an HTML widget?
At the moment you can use this code. Modify widgetId, address and query selector as needed. Later on we'll add a more convenient way of listening to group address changes for a particular widget.
const widgetId = 28 const address = '0/0/21' const values = {} let widgetEl function updateWidget() {   if (widgetEl) {     widgetEl.querySelector('.value').textContent = values[address]   }   } localbus.listen('object', address, (value) => {   values[address] = value   updateWidget() }) Visu.on('widget-ready', widgetId, ({ widget }) => {   widgetEl = widget.getEl()   updateWidget() }) Visu.on('widget-hide', widgetId, () => widgetEl = null)
